removing plastidip
Old Jul 5, 2011 | 12:50 PM
Mark2K8's Avatar
removing plastidip
Whats the easiest way to remove plastidip? I did my grill with it 6 months ago, and now I decided im gonna paint it right cause I want the glossy look, but its such a bitch to remove it. I added another layer of plastidip 2 months ago so now its like 2 layers so thats probably why. is there any material that straight up removes it easy?
Old Jul 5, 2011 | 12:56 PM
AmeRikaZmoStWaNteD's Avatar
just paint gloss black over the plasti dip..i did three months ago still holding strong..
Old Jul 5, 2011 | 01:09 PM
Mark2K8's Avatar
Heres how it looks now:
I havent touched the lower grills. And Idk how ima peel off the end of it/under. I have the primer, paint and clear coat. You guys think it'd be ok to just start primer right now on top of it all?
Old Jul 5, 2011 | 01:10 PM
0MGHI2U's Avatar
just peel it off
Old Jul 5, 2011 | 01:11 PM
0MGHI2U's Avatar
if not get like paint stripper and try that
Old Jul 5, 2011 | 01:12 PM
Mark2K8's Avatar
Originally Posted by 0MGHI2U
just peel it off
Im trying, and its peeling off like 1mm at a time. Cause its 2 layers. Ive done it before on my sidemarkers and it peeled off easy, but this is different.
Old Jul 5, 2011 | 01:13 PM
gwood5turbo's Avatar
thats unfortunate.. I think i would get that peeled off before started painting. g/l
Old Jul 5, 2011 | 01:15 PM
LordFappington's Avatar
Gas, goo gone, petrol based removers.
Old Jul 5, 2011 | 01:24 PM
Mark2K8's Avatar
this?
http://static.www.odcdn.com/pictures...7686_sk_lg.jpg
Old Jul 5, 2011 | 01:31 PM
Illuminati's Avatar
Easiest way is to make enough coats to peel it off easier. Also goo gone and WD40 work wonders
Old Jul 5, 2011 | 01:39 PM
Yes
Old Jul 5, 2011 | 01:52 PM
Mark2K8's Avatar
Alright just tried wd-40. worked pretty well.
took off most of it. now its just a couple of black smudges here and there.
How do u guys propose i go doing the next grills. Straight up wd-40 or peel off as much as I can and then wd-40 it.
And i appreciate the help everyone
Old Jul 5, 2011 | 01:55 PM
If you use any of the mentioned products, youre going to have to clean it real well before you decide to spray anything on there otherwise youre gonna have bubbles, runs, and flakes.
Illuminati's Avatar
I suggest like 3 or 4 coats of plastidip it will be so much easier to remove at a later date. Then anything else just remove it with the WD40
Old Jul 5, 2011 | 01:58 PM
Mark2K8's Avatar
Yea once I get it all off ima clean it and wash it REAL well and let it dry overnight and paint it tomorrow.
I have plenty of coats on it. Thats the thing. I painted it 6 months ago, and added more coats like 2 months ago. Its thick enough, but when I peel it, it peels in layers (cause i did it twice). It doesnt come out thicker, it comes out in layers. U know what im saying?
