What is this noise???
Old Jul 11, 2011 | 06:14 PM
syshs's Avatar
Issue resolved: Driver side o2 sensor had come a bit lose... had to go get a 22mm wrench... done.
It was still inside the TP but at certain rpms was vibrating mad inside the TP.
Old Jul 11, 2011 | 06:21 PM
diablo350GTR's Avatar
good new! I'm glad.. good to know now i can check around there next time I hear something..
Old Jul 11, 2011 | 07:19 PM
mammeor's Avatar
Originally Posted by herrschaft
Probably just a heat shield or something with the piping. You should be able to pinpoint it if you put the car on a lift.
I have a current rattling sound too, got my car on a lift and started banging on everything, found that my drivers side TP sounds like there is something loose inside of it.
I believe the rattling at low rpm is the heatshield. It comes loose after a while, same prob in my car. Some ppl remove it and rattling stops, it's up to you.
Old Jul 11, 2011 | 07:21 PM
syshs's Avatar
^ pls read my post 2 posts up.
mammeor's Avatar
cool good to know i didn't see your post so I thought it was the heat shield
Old Jul 11, 2011 | 08:42 PM
herrschaft's Avatar
Glad you figured it out
The heat shield directly above the TP did rattle slightly when I hit it but it wasn't the same sound. When banging the TP there was clearly a distinct rattling sound which I couldn't pinpoint. And I checked both O2 sensors at the time but they were tight.
Old Sep 1, 2011 | 05:53 PM
DrMax's Avatar
Is there can be negative point about removing the cat heatshield or it doesn't really matter?
Old Mar 4, 2012 | 10:55 PM
CFitz's Avatar
I hate to "raise an old thread from the dead" but I am wondering the same thing. Could removing the heat shield damage anything?
Old Aug 22, 2013 | 06:42 PM
MicntaeG35's Avatar
Sorry to revive an old thread but it's better than posting a new one. I just had my tdx v2 + art pipes installed and occasionally I hear a "clanking" noise. Itaalmost sounds like something hitting either the exhaust or TP. Anybody have a clue what it might be? Any help is greatly appreciated
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
