What is this noise???
In the video below you will hear the rattle when the rpm is between 2k-3.5k rpm. Its very prominent, as the rpm falls after I let my foot off the gas.
Sounds like its coming from underneath the car.
video link -> http://flic.kr/p/a25FaQ
I dont think it has anything to do w clutch/flywheel.
Blown exhaust gasket? Heat shield rattle? Something else?
I have had resonated test pipes for couple of months now and this noise just started this morning.
I know mine was making noise with quick rev to 3k n let it drop slowly...
Got HFCats got rid of that sound but now there is a different sound lol. You cant win with these cars...
Also heatsheilds tend to get loose sometimes.
Probably just a heat shield or something with the piping. You should be able to pinpoint it if you put the car on a lift.
I have a current rattling sound too, got my car on a lift and started banging on everything, found that my drivers side TP sounds like there is something loose inside of it.
yea, im really hoping its something easy like a heat shield loose.
I know, but thats what is sounds like
yes, even my noise seems to be coming from around the driver side... i think its the heat shield above the TP hitting it... but again, im not sure.
i need to get it on a lift... have a person rev and the other pin pointing where the noise is coming from.
i can bet its something else.
^ yup, read it, thanks.
im leaning and hoping its a heat shield or TPs or a bolt or the o2 sensor or a combo that are lose, which is causing the noise. i will have somebody check it out soon.
will post update.
will post update.
