5AT Owners that use MM Mode more than Auto
Old Jan 16, 2005 | 04:42 PM
RussB's Avatar
it will not upshift for you but it will downshift on it's own. as for downshifting it yourself, the 05's are built for it, they have a rev match feature that's really smooth.
Old Jan 16, 2005 | 05:56 PM
maz's Avatar
maz
Hi guys and galls!
Thanks for the question, I was about to post it myself, but someone went ahead and did it.
One thing though, I was going to ask – for the most optimal torque/hp/speed increase on highway or on the street – you’re on a highway/street in auto, and you need to accelerate reaaaaaaaally quick (to kill that jerk or for whatever reasons), what are your actions?
Hit the gas pedal and then shift to MM
Shift to MM – hit the gas pedal
Hit the gas and shift to MM at the same time
Hit the gas and shift to MM at the same time and downshift to 3rd?
…anything else…?
Thanks!
Old Jan 16, 2005 | 05:57 PM
DiamondGCoupe's Avatar
as far as smoothness goes you just have to get used to downshifting with it and braking then realeasing as you downshift. It takes some time to get used to ive driven MM on my 02 Audi and G every mile of em. one thing is true it will not shift from 1-2 like audi or whatever else does which kinda sucks but what can you do it's best to have vdc off when using MM so you dont bounce as often off the limiter also try not downshift above 3K rpms
Old Jan 16, 2005 | 07:37 PM
Ianbiz's Avatar
I know in the 99TL I can get up to 40mph but its a 4 speed, in auto you only get up to around 30-35 and then the car will shift, but in SS you are on your own.
Old Jan 16, 2005 | 09:13 PM
billiken's Avatar
no offense meant, but i've had my car for six months and use MM all the time. if you guys are hearing a "clunk" there is either something wrong with your car, you are making some horrible shift decisions, or both. you should be able to brake in MM without a clunk in ANY gear. as you're braking, just leave the gear alone because the tranny will downshift on its own as you either stop or slow down. at a slow roll the car will drop to 2nd or if you stop completely it will drop to 1st on its own. if you're talking about braking into a corner and accelerating out of it, i would just drive the car as if it were a manual.... just make sure the tranny has grabbed the gear before you mash back on the gas. hitting the gas before a gear has been engaged may be an instance when you might hear a clunk. I'd obviously not make a habit of bouncing off the rev limiter. you're being rough on the engine and the VQ loses a bit of steam just before redline anyhow, ....so it makes no sense to ever bounce it.
Old Jan 16, 2005 | 09:27 PM
GQMO16's Avatar
Oh yeah another thing, do you have to take ur foot off the accelerator when u shift in MM mode like in regular stick?
Old Jan 16, 2005 | 10:45 PM
TedRuxpin's Avatar
I have an 05, and Ive gotten close to redline. There is a rev limiter..is it in the redline area/
Old Jan 17, 2005 | 12:12 AM
decoy's Avatar
Originally Posted by Gaaaar
Hey how do you guys drive in mm mode all the time? I always feel uncomfortable when im braking while driving in mm mode. Do you guys downshift while braking to put your car in a lower gear, or do u guys just keep it in gear and let the car automatically shift to a lower gear? Because i realize when i downshift in mm while braking i get a sudden uncomfortable jerk. Like all of a sudden im stopping alot harder. So usually when i drive in mm mode and say theres a redlight, i just shift to D and then slow down. Is that what you guys do?
REMEMBER TO ADD GAS WHEN ENGINE BREAKING - THIS PREVENTS THE CLUNK/JERK OR WHAT U MAY CALL IT
IT MAY BE COUNTER INTUITIVE, BUT IT'S TRUE
sorry about the cap locks.
I love a MM car, saves me from grief in traffic =)
Old Jan 17, 2005 | 01:51 AM
Sickone's Avatar
the 05 coupe(this is what I have)
- Will not upshift in MM on it's own no matter what. If you take it past 6600RPM the rev limter kicks in, but gear remains.
- due to slight delay when shifting, if you are pounding it hard you need to hit the shifter at 6200- 6400RPM so it shifts by 6600 to avoid the limiter
- The system WILL prevent you from downshifting to too low a gear/at too high a rev.
i.e. you can't downshift to 2nd at 80MPH
When used correctly MM can offer amazing results
1st is good to 30MPH, 2nd to 60MPH, 3rd to 90MPH
3rd becomes very useful in freeway passing, i.e. move to MM, (it will start in 4th) down shift to 3rd, stomp it to the floor and fly by the bozo doing 58 in the fast lane.
Old Jan 17, 2005 | 01:57 AM
Omar's Avatar
Head 'n Shoulders
No you dont have to let go off the gas when you switch gears in MM. I cant drive in regular D any more. Ever since I learned to use the MM, its just not the same in D. I think im a control freak or something
Old Jan 17, 2005 | 10:22 AM
VinNYCG's Avatar
G SQUAD
What are top speed people are getting per gear?
I'm averaging:
1st - 30 mph
2nd - 50 mph
3rd - 70 mph
4th- 85-90 mph
5th- the remainder
-Vin
invincible514
Sep 21, 2015 07:05 PM
mattdg35
Sep 14, 2015 11:28 AM
Cbohannan101
Sep 12, 2015 10:32 PM
FRUG35
Sep 11, 2015 03:07 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
