AC Clutch disc missing.
Old Jul 12, 2011 | 01:57 PM
nautica_t's Avatar
Has anybody had this fall off what did you do to fix this problem? Mine is missing, I'm going to buy a re-built compressor and remove the clutch disc and bolt it onto my compressor. My compressor is not engaging when I press the ac button, everything else works, the fans turn on. I went to Infiniti and they thought it was low on pressure for freon. We removed 1.2 pounds. and than put back in 1.2 pounds. So there is no leak. Just wondering if I can just bolt on the clutch disc from a new compressor and it'll fix everything.
Or should I remove the pulley as well, only reason, is I don't want to remove the compressor if its just the clutch disc missing.
Old Jul 14, 2011 | 10:17 AM
nautica_t's Avatar
anybody?!?!
g.spot
May 9, 2016 10:54 PM
NailBomb
Oct 28, 2015 07:53 AM
AL8782
Oct 3, 2015 10:26 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
Jpete
Sep 25, 2015 01:38 PM
