SPC Camber Kit...Any success with inner tire wear?
Old Jul 20, 2011 | 02:09 PM
eNDleSs's Avatar
Originally Posted by mattyboyl
I am not lowered. My car has the sport suspension with the 19's. The shop got it as close to spec as they could with the stock set-up and my inner tread wore out so much, you could see the threads of the tire and the rubber had holes in it! So according to my research, it seems that the control arms (camber kit) will indeed resolve this issue. I'm going with SPC since it has received good feedback. I want to avoid the cheaper ones because I don't want to run into anymore problems due to lack of quality with bushings etc. Thanks to this forum, I was able to save a lot of money, aggravation, and heartache! So thank you fellow G enthusiasts!
Stock sport suspension and your shop couldn't get it into spec? Take your car to another shop.
Old Jul 26, 2011 | 12:25 PM
mattyboyl's Avatar
Taking my car next week to a shop recommended by two mechanics. This guy has been in business for 14 yrs and all he does is alignements. I'll keep you posted.
Old Jul 26, 2011 | 12:51 PM
nghiars's Avatar
definitley take it to another shop if you're stock and the shop was unable to get you into spec.
Old Apr 28, 2016 | 09:03 PM
Duinit's Avatar
I had my G35 aligned and my fronts are wearing excessively on the inside edge. Unfortunately I can't rotate as they are all season tires with inside/outside tread. Can this be fixed without aftermarket camber arms or am I doomed to invest in them?
Old Apr 28, 2016 | 11:36 PM
Mignav01's Avatar
need a camber kit. camber isn't what kills tires, the toe is usually what speeds up the wearing of a tire
obender66
18 Inch
Mar 13, 2016 12:20 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
socalg35x
Aug 7, 2015 09:36 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
