Alarm Issue (Vid inside)
Old Jul 20, 2011 | 05:57 PM
dEnbOy.GFM's Avatar
Originally Posted by Baliztik
I thought that square was the transponder for the start function. The transponder should only be active when it's near the ignition. That's why remote starts have a bypass where you hide one of your keys in the bypass module and that acts as the transponder so your car can start.
Yeah the transponder activates when you turn the key in the ignition which then allows you to start.
However I think proximity has something to do with how the alarm activates and I assume the chip is what allows that to happen. I'm not certain, which is why I'm telling the guy to try and see what happens. That way he can come back and either confirm or there's another problem. It seems to work for me so IDk.
It could also be a time delay. Try waiting like half a minute then unlock the door.
Old Jul 20, 2011 | 07:20 PM
BigOgre's Avatar
I will take your advise. I just haven't found time to do this.. I will do this and get back to you guys with results.. Thanks for everyone's input.
Old Jul 20, 2011 | 07:46 PM
dEnbOy.GFM's Avatar
Be sure to check if it's a time delay too.
Old Jul 20, 2011 | 07:49 PM
BigOgre's Avatar
Lock it and leave the key away from the car and wait right?
Old Jul 20, 2011 | 08:00 PM
speedracerg35's Avatar
The only way to check your factory alarm is to set it with the fob while sitting in it. Wait 30 seconds and open the door by flipping the toggle on the handle and pulling the door handle open.
Old Jul 21, 2011 | 12:54 AM
BigOgre's Avatar
Would that have the same effect if I locked it and popped the trunk or hood
Old Jul 27, 2011 | 02:07 AM
nope. only unlocking without a key and opening a door will trigger the alarm.
Old Jul 27, 2011 | 02:38 AM
jibberjabbers's Avatar
Can anyone help me with this issue? I hope this video can help you guys understand what I'm talking about. It seems like nothing will set the alarm off. Like opening the doors, hood, trunk.
http://www.youtube.com/watch?v=aOCH7QUA76M
Ps. Yes my car is super dirty I just came back from Vegas lol..
LOL. When you UNLOCK the car with the key, it disables the alarm.
Probably put in place so that if the alarm fob was dead, you can still drive and get into the car.
Old Jul 27, 2011 | 11:05 AM
richardcvan's Avatar
i might know the solution... when you lock the car it takes about 30 seconds delay to activate the alarm.. there should be a red LED light in your car.. when you lock it it will be solid red for like 30 seconds.. when it starts to blink that means the alarm is activated.. try this and tell me the result
chinee
Jun 10, 2024 07:48 PM
Frostbite91
Aug 20, 2015 07:20 PM
JMSABO
Aug 4, 2015 11:58 AM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
