Few questions before I change my clutch fluid
Old Jul 24, 2011 | 05:57 PM
MurByrne's Avatar
Hey guys,
Just wondering which fluid i should replace it with exactly? Curious what others have used and what they were happy with. Just assuming any old DOT3 brake fluid will work?
I plan on following this DIY thread here:
https://g35driver.com/forums/engine-...ange-pics.html
Old Jul 24, 2011 | 06:13 PM
faiz23's Avatar
Motul if you can get it or prestone dot 4 locally. Stick with Dot 4 since it has higher boiling point and your fluid will last longer. The clutch pedal has a tendency to stick when fluid is old and moisture in in the fluid.
Old Jul 24, 2011 | 06:57 PM
dEnbOy.GFM's Avatar
Motul RBF600 hands down, bar none.
Old Jul 24, 2011 | 08:27 PM
MurByrne's Avatar
Got it. I'll see what I can find locally. I'll probably just stick with DOT3 since that's what was already in there, and what is recommended by the manufacturer. I mean, is there any evidence that DOT4 is really better in our cars? I'm going to flush the system, but isn't it possible that there would be left over DOT3 and it would mix with the DOT4? Don't know if that makes a difference or not....
Enlighten me please
Old Jul 25, 2011 | 01:17 PM
MurByrne's Avatar
Also, another question...how much will I need to buy to completely refill it?
Old Jul 25, 2011 | 02:24 PM
rob40wilson03's Avatar
bump for quantity.... 102 degrees the other day and pedal got squishy and started sticking while i was driving pretty hard
Th611
Oct 27, 2015 03:48 PM
NemesisGee
Aug 11, 2015 07:10 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
TurboEE
Jul 31, 2015 10:41 AM
