Need help with rims+tires
Old Jul 27, 2011 | 08:14 PM
JDM`'s Avatar
These are the rims i am still deciding to get.
Something that has a dish lip like Rohanna RL-06(Matte Black)
Or Varrstoen 2.2.2 (Matte Black)
So please help me decide guys.
-I have a 06 OB coupe and its going to be dropped in MR Coilovers soon.
And also I am noob to wheels.. I have no idea what offsets are and what they do and how would they look like..
thanks
Old Jul 27, 2011 | 08:52 PM
4D05G35's Avatar
http://en.wikipedia.org/wiki/Offset_(wheel)
https://g35driver.com/forums/picture...some-nsfw.html
http://www.1010tires.com/wheeloffsetcalculator.asp
That will get you started in the right direction.
Old Jul 28, 2011 | 08:16 PM
JDM`'s Avatar
so Negative offsets makes the wheel stick out more or something??
Old Jul 28, 2011 | 08:57 PM
CharlesHubular's Avatar
^ this.
Old Jul 28, 2011 | 09:07 PM
JDM`'s Avatar
this what? im noob
Old Jul 28, 2011 | 09:25 PM
JDM`'s Avatar
i dont get it
Old Jul 28, 2011 | 09:33 PM
dEnbOy.GFM's Avatar
"THIS" meaning "YES"
And also, they're telling you to search. Go to the wheels section in the forum, tons of info there.
Old Jul 28, 2011 | 09:34 PM
Those lines are where the wheel bolts to the hub. The lower (more negative) the offset the more "tucked" under a fender a wheel will be. The higher (more positive) the offset the further it will poke. Follow the links provided above and do a little research to see what you like.
19" Varrs +0 offsets will fit like this:
You could even add a little more low and more negative camber.
Also, These wheels will definitely require a fender roll. Most competent body shops can do this in about 30 mins or less.
Old Jul 28, 2011 | 10:05 PM
walshtj's Avatar
^ Great post and great info!
Old Jul 28, 2011 | 10:31 PM
JDM`'s Avatar
So for those rims you gotta get a body shop to do a fender roll which means redo the fenders and make it wider?
Old Jul 28, 2011 | 10:56 PM
Right, especially once you get your coils installed. Only the rear fenders will need a roll, the fronts are factory rolled.
WomBadtz
19 Inch
Jun 25, 2012 10:32 AM
fortunecookie93
Feb 13, 2010 01:04 PM
johnsonp
Intake & Exhaust
May 7, 2009 03:26 AM
