A bad engine bank?
Old Jul 28, 2011 | 12:16 PM
Gem352004's Avatar
A bad engine bank?
I went to my mechanic and he say I have a bad engine bank. What does that mean? I thought the engine bank is where the cyclinders sit. Maybe im wrong. Not to sound stupid.
Old Jul 28, 2011 | 01:20 PM
TannerG's Avatar
That's where you keep all the extra engines that you earn. Make sure to get one with a good return rate.
Old Jul 28, 2011 | 01:30 PM
LoSt180's Avatar
Only thing I've seen referenced as bank has been Oxygen sensors (ie: sensor 1 bank 1). Your mechanic should be more specific as to what the problem is.
Some gee-wiz info is that the Right Bank is Bank 1, and the Left is Bank 2. (Left is driver's side in this case.
slim17265's Avatar
it means 3 cylinders are not firing...all on one side.
Old Jul 28, 2011 | 02:19 PM
GR6RR's Avatar
Means he needs more bank rolls to tell you what your problem is..
Old Jul 28, 2011 | 02:58 PM
calcul8's Avatar
I can haz potato?
sabertooth tiger
Well, I'd obviously start looking for a better bank. How about Valves and Cylinders Savings & Loan, I've heard good things about them.
Old Jul 28, 2011 | 10:04 PM
chink-ah-saur's Avatar
Seafoam
Old Jul 29, 2011 | 05:33 AM
dofu's Avatar
20 Year Member
^ And make sure it's from the Atlantic Ocean, not the Pacific.
Old Aug 2, 2011 | 07:07 PM
andrewstclair's Avatar
a bank is a side of the engine so either the left three cylinders or the right three cylinders. a bad bank can mean that one side is running lean or rich. an engine light will show up if this is the case. they cant be completely bad as in not running at all because your car WILL NOT run on three cylinders alone. if there is no engine code showing up then he is most likely a retard.
Old Aug 2, 2011 | 11:06 PM
Massios's Avatar
Dude I would switch banks, finance rates are at record lows.
I got em so low the HKS iRS make me scrape everywhere I go.
Old Aug 2, 2011 | 11:12 PM
MADtotheA's Avatar
What a helpful post. Maybe ask your mechanic what in the hell he is talking about? Maybe 02 sensors but who knows? I live in the south and it's hard to understand some mechanics lol
Old Aug 2, 2011 | 11:28 PM
G35SHAWN's Avatar
There is Bank 1 & there is Bank 2. The Passenger side is bank 1 (cyl 1, 3, 5) & the drivers side is bank 2 (cyl 2, 4, 6). Also if you did you get SES (service engine soon) light on the dash?
Muski_G
Dec 1, 2023 11:11 AM
StephonW
Aug 29, 2015 01:24 AM
KevinnnVo
Jul 28, 2015 06:29 PM
newg37
Jul 26, 2015 09:32 AM
