'04 G35 will not run after Plenum Spacer install
Old Jul 30, 2011 | 04:47 PM
MyaLover's Avatar
I installed both the Motordyne Plenum Spacer and AEM CAI. This pretty much wen as expected. I had the battery disconnected for about 4-5 hours while working on it.
When I was I done, I went to start the car and it will not run. All dash lights come one and when the key is turned, the car starts right up. However, it dies within a second. I'm fairly certain it's an immobilizer issue as I've seen similar behavior on an Audi.
I tried the reset functions in the manual and I also disconnected the battery again and pumped the brakes to reset the ECU.
Anyone have any ideas?
Old Jul 30, 2011 | 05:01 PM
G35SedanGrn's Avatar
did you plug the maf sensor back in? Most likly a bad maf & it has to do with the intake install not the spacer.
Old Jul 30, 2011 | 05:06 PM
superchargedg's Avatar
Also did you plug the throttle body back in.
Old Jul 30, 2011 | 05:15 PM
AuAltima3.5's Avatar
Double check all your connections (electrical).
If it was a security issue I think we have a dummy light for that.
Check the battery for charge, too.
MyaLover's Avatar
Well I let it sit for 20 minutes or so while I was researching and when I went back out to try it again it started right up and stayed running. Very strange.
Took it for a ride as well and things sound totally different at 4.5K RPMs.
Thanks for the suggestions guys.
Old Jul 30, 2011 | 05:58 PM
PAIXAO's Avatar
Hmm. My first guess would have been a vacuum leak. Glad it worked itself out.
Old Jul 30, 2011 | 10:37 PM
wbama387's Avatar
I was thinking the same thing. Did you attach all the vacuum lines back to the plenum. Sometimes it will run and sometimes it wont but if it does run its going to run like crap.
Old Jul 31, 2011 | 12:59 AM
Rodrigo's Avatar
Your plenum spacer has a small leak , your mafs is good this happened to me a while back and I realized that a small leak caused the car to shut off ,
You may think the car is running back to normal but it's not . The ecu is correcting what it senses is wrong ,changing your a/f ratio .
If you run a live diagnostic you will be able to see that the signals are off factory spec and the ecu is constantly adapting learning the idle ..
I corrected this by taking the plenum off again and reinstalling it as per the FSM tightening sequence. Used some carb cleaner to see if I still had a air leak , the cleaner will spike the idle if in the are sprayed there is a leak . If nothing happens then your idle is at 650 rpm and your good .
Old Jul 31, 2011 | 11:30 AM
irishsig's Avatar
If there is a leak make sure that the rubber collar around the oil cap didn't get caught in the upper plenum reinstall.
This tends to happen a lot with installation of plenums.
Old Jul 31, 2011 | 04:49 PM
Yep as i had that happen too!
Jusseth
Sep 13, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
Ninjay16
Jul 20, 2015 01:21 AM
