Stock everyday driver. Clutch kit will need to be changed soon. Did not know if O.E. is the inexpensive way to go.
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
The best aftermarket clutch is the ACT kit but they're not cheap, the best never is! Do some research, call Nissan and find out what a OE clutch would cost you then Google ACT and compare prices. I'd stay away from the Infiniti stealership since the OE clutch will no doubt cost you 30% more since the use the best materials....yea right!
Gary
Gary
faiz23
close
- Join DateNov 2006
- LocationYour mom's bed
iTrader Feedback Score(2)
Liked:291 Times in 218 Posts
If you want OEM then check Sewell price you can't beat it with the G35discount
http://infiniti.sewellparts.com/oem-...oupe-2006.html
faiz23
close
- Join DateNov 2006
lol...why you no like SEDAN
Should be same part but if that makes you feel better same price with G35 discount.
Sign up here for discount
http://infiniti.sewellparts.com/g35driver.php
The description is confusing. OEM replacement is not OEM. It's a cheaper copy.Originally Posted by faiz23
lol...why you no like SEDANShould be same part but if that makes you feel better same price with G35 discount.
The Exedy will run $260 shipped! So for $110 more or so (with the discount) I can go with the O.E. replacement...is it worth the extra $$$.
gary c
close
- Join DateFeb 2005
Quote:
It would be worth paying the $ for a OE clutch not a replacement now rather that doing the job again in a few months cause you bought junk. Don't forget the throw out bearing too, those must be replaced with the clutch!Originally Posted by RMA
Gary
