Anti-theft wont let me start my car
That key does not have a battery. It uses radio signals. The car sends the signal to the key when you stick the key in the ignition and turn it. If the signals match, the car will start.
All the key has is the chip. No battery.
And I think it's time you suck it up and just take it to the dealership already. lol
Update:
Just got my car towed to Nissan dealership.
They already ran a diagnose of my car.
The problem right now is the car could not read the chip on my key.
They replaced the NAT on the antenna and that didnt work and got charged $405 for that, BS !!
Now I gotta leave my car over night at the shop as they continue working on it tomorrow. They need to place another part.
The total outcome right now is $405. When tomorrow come, they gonna put another part which will prolly cost another $100-200. And my total would be up to $500-600.
This. You shouldn't have to pay for something that didn't fix your problem. Unless you told them to do the work before they diagnosed it which I know you didn't. Go raise some hell. After they fix the problem, of course.
i think that is my problem...i haveto check the fuses..can someone tell me where can i check all those? when i give it a jump, i have to connect the power+ cable to a screw on the terminal connectors on my batt...if i do it to the terminals it wont start, just the click and the panel turning on..please advice
Yes.
They diagnose my car. Then they told me what they are gonna replace.
They told me "It could be something wrong with the NAT so its not picking up my key."
So they told me that they are gonna replace my NAT which cost $405
After that they told me that it didnt work.
When they worked on it today they said my BCM (Body control module) is bad and it will cost $1000. So instead of getting it for $1000 i bought a use one for $140 off a 06 G35 Sedan and they are gonna try to reprogram it tomorrow. (06 G35 Sedan BCM has the same part and model number as my 06 G35 Coupe)
When tomorrow comes they gonna make up some BS saying it didnt work and need a different part then my $140 BCM i bought would be useless and its non-refundable.
*** dude sounds like my problem.!they replaced my bcm already! Labor n parts was 600+ n 3 hours of diagnostic which is another 4 so I'm at 1000 n today is when I find out if ghat has fix my problem or not. How did urs go? Got it fix ? wat else did they do?
They thought it was my NAT problem so they went ahead and changed the NAT and that didnt work. Now they told me it was my BCM problem. I didnt want to get charge so i bought a used NAT which came off a 2006 Sedan. They installed it and reprogrammed the BCM to my car setting which they saved from the old NAT. Then voila it worked !
make sure they reprogram the BCM correctly, if they know what there doing other wise it would never work.
well i finnally got a chance to talk to them. the have replaced the bcm today n nothing changed car still wont start. now they say there r no output from the bcm to the nat attena. so pretty much they suggest a new nat blah blah. n hope it will fix the issue. i told them if changing my bcm didnt do shiet y r they charging me on my parts n labor, she reply that they will reinstall the old one n see if it works n if it does they will return the bcm but still charge me 1hr of install i was like wtf?? so yes ima raise hell once they fix my shiet n i just hope its the nat. i want my car in mobile mode.
thanks for the fast reply. what else what going on with ur car when it didnt start? my symptoms were the radiator fan were on, the security lights stayed on when on acc. n crank but no start, did u have the same symptom?
u mentioned replacing the bcm n also the nat. n u said the nat didnt work so did u end up just replacing the bcm n return the nat? or vi-versa or did they replaced both parts?. because so far wit mine they replaced the bcm n that didnt do shiet n their next move is to replace my nat.
Yes they replaced both parts. But, after changing the BCM we didnt change the NAT back to my old original one, we didnt bother since the car is running and working.
And what happen to your car? were you messing with the positive terminal on the battery? Cause my positive terminal wasnt tighten up so when im driving it keeps popping up.
