Alternator replacement procedure
Old Sep 6, 2011 | 03:47 PM
bythabay's Avatar
Just replaced an alternator on an 03 G35 Coupe 5AT last night with the electric fans. To get the alternator out I just followed the FSM instructions, however, the instructions were somewhat incomplete in that they did not instruct to disconnect the upper radiator hose and to unbolt the AC line bracket on the driver's side. There is no way that the cooling fan assembly could've been removed without loosening the AC line and disconnecting the upper radiator hose.
The reason the cooling fan assembly really needs to come out is because the main alternator mounting bolt is too long to be removed if the cooling fans are in place. Luckily though, the cooling fan assembly comes out really easily, just 2 screws on top, a plastic reusable zip tie on the bottom; alongside two electric connectors.
Just some useful tips for anyone trying to tackle this.
Old Sep 7, 2011 | 12:06 AM
gary c's Avatar
Check www.infinitihelp.com for complete instructions on R & R of your alternator.
Gary
Old Sep 7, 2011 | 06:11 AM
Blue Dream's Avatar
I drove ttrank's car solo
Thanks Eugene, you're a wealth of info on all things G. Your DIYs have helped me a lot, I just wish you posted more.
Old Sep 7, 2011 | 01:40 PM
bythabay's Avatar
I do what I can, thanks
Old Sep 7, 2011 | 01:42 PM
faiz23's Avatar
Yeah man had to give you a couple thanks since you have done a lot for the community and asked for nothing back in return. Appreciate all your work and look forward to more guides and videos.
Old Sep 7, 2011 | 05:52 PM
LMG_35C's Avatar
^ +100 Your contributions are what make communities like this really useful. I, and I'm sure many others, thank you.
Oh, and the FSM for my 04 does say you need drain and remove upper radiator hose to remove the fan assy. gottta follow all the links in the manual but it's there.
Old Sep 7, 2011 | 05:54 PM
redpearl99's Avatar
Did you happen to film it as another installment in your epic series??
andyg35c1
Aug 29, 2015 03:37 PM
dimentio1
Aug 16, 2015 11:47 AM
sclair
13
Aug 7, 2015 05:43 PM
brian_z
Jul 22, 2015 09:19 PM
