Low beam light messed up
Old Sep 16, 2011 | 08:25 PM
Mark2K8's Avatar
My low beam for my right headlight went out, so i bought new lights, but they didn't work too. Tried it on the left side and it worked, so it wasn't the lights that weren't working.
My fog lights work, my turn signal light works, my clearance strip works, just the low beam doesn't. So its the wiring/fuse for it.
anyone else have this problem? any solutions?
any help would be appreciated
Old Sep 17, 2011 | 03:22 AM
MADtotheA's Avatar
It's not a fuse. Both headlights are on the same fuse. It has to be a wiring problem. Depending on your electrical knowledge, I would say to take it to the shop for them to determine the root problem.
Old Sep 17, 2011 | 01:44 PM
Mark2K8's Avatar
Yea I'm pretty sure its the ballast. Opened the lights up. like a gallon of water came out (including water dripping from the ballast) from heavy rain. so i guess i need a new ballast?
Old Sep 17, 2011 | 03:27 PM
IHIERBal's Avatar
You could swap the ballast from the other side just to be sure.
Old Sep 17, 2011 | 04:06 PM
Mark2K8's Avatar
I did, and it worked!?
Then I swapped them out again and now NONE of them work now...? wtf
Old Sep 17, 2011 | 06:18 PM
Blue Dream's Avatar
I drove ttrank's car solo
Don't go to the dealership, they want $560 for a new one.
But, I have an extra I'll be happy to sell you. I can tell you it works, but don't know the history of it. My ballast on the passenger side went out a couple of months ago and I bought a pair from a member on here. $100 shipped to your door and it's yours. It's too late here for it to go out today, but I can send it Priority Mail on Monday if you'd like. It also has the cable that plugs into the back of the bulb, I think that's called the igniter. I was going to keep it as an extra but since you need it now I'm willing to part with it.
LMK
Old Sep 17, 2011 | 10:15 PM
Mark2K8's Avatar
I just let the ballasts dry for a couple hours and now both work perfectly... I guess water caused a bad connection.
Thanks anyways bluedream
Old Sep 17, 2011 | 10:19 PM
Blue Dream's Avatar
No worries, just means I get to keep my spare.
Glad you got it worked out, can you believe Infiniti wants over $500 for that little piece?
Old Sep 17, 2011 | 10:55 PM
Mark2K8's Avatar
I'd believe any price you give me once the word "dealership" is mentioned.
Old Oct 30, 2011 | 06:11 PM
kpowe1's Avatar
I replaced or so called replaced my driver side headlight after I noticed it was dimmer then the passenger side. ( I had the passenger side replaced after it went out over a year ago) The driver side bulb that was in there was working went I took it out a replace it with a new one. The light never came back on. Any suggestion
Old Apr 4, 2012 | 08:59 PM
stevenpiazza's Avatar
i have been having the same problem recently. last time the light stopped working was when it rained. day after it worked just fine. washed the car today and the light wasnt working again. must be the ballast for me to?
thanks!
Old Apr 5, 2012 | 12:53 AM
Mark2K8's Avatar
thanks!
Most likely water is getting inside the ballast...
Jusseth
Sep 13, 2020 12:25 PM
itztwinki3
Lights
Oct 15, 2015 04:38 AM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
EasySausage
Jul 20, 2015 03:56 PM
