G Coupe about to Hit 50k, maint. question?
Old Sep 26, 2011 | 01:42 AM
jdmeg21's Avatar
Well my G is sitting at 49,998 miles as of right now and I want to know what things I should be looking at to replace (belts, pumps plugs???). Car is 5 years old thing year and I'm the original owner.
looking at change out
Brake fluid
Steering fluid
belts
spark plugs
I've change out trans and pumpkin fluid.
anything else I should look at?
Old Sep 26, 2011 | 09:43 AM
Emart1290's Avatar
Pretty sure there isnt a need to change the plugs before yur a little closer to 100k i know a few people that have done it a little over the 60k mark but one thing to check on is if your car is still under powertrain have them check the valve cover seals and make sure no oil is leaking. Other than that, if your belts need to be changed you can tell by checking the lanes on the belt. If they are worn theyd be wider and uneven and if theyre starting to dry rot they will be beginning to crack. I just changed mine myself at 55k only one really needed to be changed by you should do both.
Old Sep 27, 2011 | 12:21 AM
2K6G35c's Avatar
At 35k, I changed: transmission fluid, rear-end fluid, had the car sea-foamed, replaced belts, cabin air filter, rear brakes. At 50K, I had the front brakes replaced. I changed out the plugs at 60K. Brake and power steering fluid doesn't seem to be as popular but, now that you mentioned it, I might change it out at 70K. Hope pointing out what I've done helps.
Old Sep 27, 2011 | 12:24 AM
thescreensavers's Avatar
Mr.202?
^ If you live in a hot climate, your PS fluid is prob going to be BLACK
https://g35driver.com/forums/g35-sed...ing-fluid.html
Old Sep 27, 2011 | 02:08 AM
walshtj's Avatar
I def need to change my ps fluid.. Close to 55k.
Old Sep 27, 2011 | 09:17 AM
gary c's Avatar
jdmeg, did you do the 30K mile service? If so you can wait a few more miles to do the next service if your belts/fluid levels are in good shape. Plugs, I'd change them at 60K just because your G might run better....but that's me.
Gary
Old Sep 27, 2011 | 09:39 AM
jstudrawa's Avatar
How are we supposed to use the Infiniti sscheduled maintenance site?
http://www.infinitiusa.com/ownership...schedules.html
If you go thru each interval, they recommend AT flushing ever 30k miles under the Premium Service (for example). But NEVER on the Schedule 1. Obviously you should at some point, but they site never reads that way. It keeps recommending it for Premium Service every 30k miles.
It seems just geared for Premium. Is there a better place/website?
kinetek
Aug 3, 2015 04:25 PM
Kal Hamm
Jul 24, 2015 08:55 AM
mjfenix
Jul 17, 2015 02:07 PM
EasySausage
Jul 14, 2015 11:17 PM
