2005 Low tire pressure light
Old Dec 18, 2004 | 11:56 AM
lexicon's Avatar
Hey, my low tire pressure light keeps coming on.
A fellwo G member reset it for more at our SFL G meet but it came back on a week later. My tire pressure seems to be fine.
Could the colder weather have anything to do with it?
(30 degree difference)
Old Dec 18, 2004 | 12:09 PM
DiamondGCoupe's Avatar
JESUS DUDE!! Are you still having problems! I don't know what to tell you other than check ur psi again, could be bad sensors. I'll call you latr see if wanna stop by i'll check it out for ya..
Old Dec 18, 2004 | 12:13 PM
XCELR8's Avatar
The rule of thumb is for every 10° Fahrenheit change in air temperature, your tire's inflation pressure will change by about 1 psi (up with higher temperatures and down with lower). The air in your tire is cooling down overnight and the pressure dropping. Once the car is driven and the air inside warms up, the pressure will come back up to where it needs to be. We did a big study on this here at work. Might want to check out the results: Tire Tech: Air Pressure
Old Dec 18, 2004 | 01:14 PM
lexicon's Avatar
Xcelr8 I do believe your right.
But even after driving for 45 minutes and going 30 miles at avging 45-50mph, my light has stayed on.
Old Dec 18, 2004 | 01:34 PM
Msedanman's Avatar
O.F. Administrator
I suggest that you get yourself a decent tire pressure gauge. I have a digital one that is pretty well foolproof ($10).
Once you have a good tire gauge, check your tires cold. I usually do mine first thing in the morning b4 driving at all. Set your pressures to spec which is on a label in a door jamb.
Check those pressures periodically because they will change, as XCELR8 says, with temp., as well as usage, slow leaks, etc.
If the low air light does not go out, and the pressures are correct, you may have to do a reset by the pedal method or battery disconnect method.
It's important to check your pressures frequently, especially when the weather changes from day to day and seasonally.
Old Dec 18, 2004 | 01:37 PM
JohnnyCham's Avatar
my light stayed on constantly when it was 40 or less degrees. i'v read the manual and it says if the rears pressure is below 30 or somthing the light will remain on. rear tire pressure rec for 18's like my 6mt coupe is 35psi. i changed all 4 to 35 and the light went away after driving 10 feet. stayed off since then. try upping the pressure on your tires.
Old Dec 18, 2004 | 06:38 PM
lexicon's Avatar
Ill give it a try, have not drove it all day.
Old Dec 19, 2004 | 01:24 PM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
I notice drop in tire presure too
due to my car is park in garage 72 degrees
outside is 38-40 degrees at 6am
1 time my low presure light came on
but its ok now
keep checking tire presure because tires are not cheap
Old Dec 19, 2004 | 01:59 PM
bocatrip's Avatar
I deliberately keep the rear tire pressures of my 04 Coupe with 17's around 3 Lbs under the recommended 30PSI to avoid the inner treads of my rears from prematurely wearing out. The fronts I keep at the recommended 30. Every 60 days or so, the low pressure light comes on. I checked the rears and they read 26lbs. The first time I inflated them back to 27lbs the light went right out. The second time it happened it was cold outside and the light would not go out after adding the air until driving a few blocks.
Old Dec 19, 2004 | 04:10 PM
kenchan's Avatar
The sedans are recommended at 30psi? If so, you should keep it around that, or
you're going to prematurely wear your sidewall. factory recommended psi is very
conservative for comfort reasons.
I have the 18" on the coupe and I have it exactly at 35psi at all times (cold) or
over inflate it to 38psi when I know I won't be driving it for a couple of weeks to
rid the chance of flat spots. Even at 38psi, I roll the car forward/aft a little bit
so that it's off the same spot on the tire for a prolong time. I then deflate to
35psi and take it out for a spin.
If I was going to take her to the canyons, I'll use 37psi.
Old Dec 20, 2004 | 05:55 PM
allforthecash's Avatar
I have been reading this post, and today i noticed that my tire pressure light WILL NOT go out. Is anyone else experiencing this in the NYC area??????????
Old Dec 20, 2004 | 07:47 PM
dubs's Avatar
I just took my car out today and the tire pressure light went off. It makes sense that the cold air will effect the air pressure in the tire. I am going to pep boys to get a digital tire pressure guage & put some air in the tires to see if it fixes this issue.... I'll let you know tommorrow if it solved this problem...btw it was 9 degrees F. this morning in queens; so this could have really messed with the sensor..
Old Dec 20, 2004 | 07:59 PM
GR8TG35's Avatar
I thought if you under inflated the tires, the two inner and outer treads would be more subceptible to wear, and if you over inflate the tire, the middle/inner tread would wear....maybe I'm wrong?
joedaddy1
Jul 28, 2015 02:58 PM
wojowojo16
Jul 27, 2015 09:57 AM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
