tire pressure light - g35 coupe
Mine does the same thing....only comes on after about 50 miles of interstate driving, then goes off after turning the car off. The first few times it did it, i stopped and checked the AP and it was fine. I don't bother anymore.
You need to verify you have at least 35 psi in each tire. I had this with my first set of Volks, there was a sticker on the inside lip causing a tire to leak. Once removed the TPS only came on when I had a nail in one of my tires which is what it's supposed to do. The TPS warning comes on when your tire pressure drops below 26 psi....fyi
Gary
Gary
When the alarm beeps and the light comes on the system is telling you one or more of your tires needs air. If the light comes on with no beep, it's telling you it doesn't recognize one of more of the sensors. If you have a full size spare, be sure to check that as well, they also have a sensor.
HTH.
HTH.
Thank you all for the info, glad this was an easy fix. Fill tire with air.
I had the same issue. While driving normally, I heard a loud beep for more than 5 seconds. I thought it's from the song I am listening to. I lowered the volume, and it was so loud. I looked at the dashboard, and noticed the tire pressure light is on (first time it happens). I pulled over to check the tires, but they seemed fine. I took it to a mechanic the next morning to check the tires pressure. He said the tires pressure are perfect. I drove aggressively for like 30-40 minutes, and it went away.
No beep tire light
HTH.
HTH.
bTanz
10-15-2015 02:31 PM
