Part of Headlight and Sidemarker out. Help pls.
Old Oct 9, 2011 | 05:28 PM
.cakestar's Avatar
So i had to replace my core radiator support and I did so. It was a pretty complicated task but I got through it. After putting everything back together, it looks like my driverside headlight is out as well as the driverside sidemarker. Whats strange is that the turnsignals, foglight, and parking like all work. its just the main projector. Is there a fuse that could have been blown that is affecting just the HID and sidemarker? Does anyone have any idea? I am not really sure where to start looking..
Old Oct 9, 2011 | 05:43 PM
MADtotheA's Avatar
I would check your wiring behind the bulbs. They may have come loose bc both side markers are on the same fuse. Same with headlights.
Old Oct 9, 2011 | 05:49 PM
.cakestar's Avatar
so if the passenger side is working then its not the fuse? I checked the wiring behind the sidemarker and it looks fine. i dont know what it could be..... grrrr.
Old Oct 9, 2011 | 05:56 PM
ThatOneDude's Avatar
Take the bulb from the passenger side sidemarker and put it in the driver side. See if it works. Perhaps just the bulbs (and a strange coincidence?). Worth a shot; sorry I couldn't be any more help x_x. One of my foglights is out (driver side) and I have NO idea why neither.
Old Oct 9, 2011 | 06:02 PM
.cakestar's Avatar
hmm thats weird, i will definitely give that a try, because before we took everything apart, everything was all in working order. i didnt know if there was some strange fuse controlling the driverside sidemarker and headlight hid... bah.
Old Oct 9, 2011 | 06:22 PM
MADtotheA's Avatar
Might as well check the fuse box behind the battery. I believe the side marker one is on the right side, 2 or 3 down from the top.
Old Dec 4, 2011 | 04:34 PM
legend95gs's Avatar
did you ever resolve this problem?
Sepsis
Feb 12, 2020 02:05 PM
wonderizm
Sep 24, 2015 03:09 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
neight
Aug 2, 2015 03:01 PM
wylin
Lights
Jul 18, 2015 06:12 PM
