Question about the HVAC system
Old Dec 20, 2004 | 04:16 PM
DJM's Avatar
DJM
When turning the heater on, the system only allows the vent to be open. And it seems that when using the recirculation mode, the air conditioning has to be on. Is there a way to turn the recirculating mode on with the air cnditioning off? Thanks and because Im the typical guy, I have not read the manual.
Old Dec 20, 2004 | 08:02 PM
P_Diddy's Avatar
When you select Recirc, I think A/C will come on automatically, but you can push the A/C button to turn it off.
Old Dec 21, 2004 | 03:33 PM
DJM's Avatar
DJM
Thanks for the reply. But, when I push the recirculate button the AC does come on like you siad. So, on my car I push the AC button to turn it off and automatically the AC turns off and the recirculate is also shut off (the system goes to vent). Does my car have a mind of its own? Or do all Coupe do this?
Thanks again.
Old Dec 21, 2004 | 03:56 PM
Msedanman's Avatar
O.F. Administrator
It's normal for our g's to act this way. Mine is same.
Apparantly Nissan doesn't want you to use the recirculation mode without the A/C. They're worried about the windows fogging up.
Old Dec 21, 2004 | 04:09 PM
GRider35c's Avatar
my friends mercedes has NO AC button... the driver can't control whether or not the AC is being used or not... i think that's just plain stupid!
Old Dec 21, 2004 | 10:32 PM
lexicon's Avatar
Which mercedes?
Both my mother (S class) and brother (C Class) have them, I haven't seen a problem.
Unless it's a CL or E which I have not seen the console, I've never heard of that before.
Old Dec 21, 2004 | 10:34 PM
GRider35c's Avatar
older (but not THAT old) C class... 2000 i think...
i'll verify the year and model later on tonight...
Old Dec 22, 2004 | 06:04 PM
DJM's Avatar
DJM
I dont like this about our cars. I want full control over the system. I want recirculation without the AC. It would get too cold in the winter with the AC on when recirculating and I will not run the AC with the heat up to adjust the temp. Waste of gas and power. Oh well, I guess the cars look makes up for it!!!
Old Dec 22, 2004 | 06:27 PM
FrizzleFry's Avatar
that's strange... i'm able to have A/C off and recirculate on... i'll double check on my drive home later.
miata007
Aug 17, 2015 04:36 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
