vdc-off,slip,and abs light came on pls help
Old Oct 26, 2011 | 09:03 AM
gsxr600409's Avatar
Had my 04 g35 coupe dropped on spring no problems for a yr . Just installed coilovers and front and rear camber kit and got alignment for 2 weeks and yesterday just started to happen lights came on for the abs vdc and slip a couple drive around the block and turn off the car starter again and drove it no lights but still hear noise from the abs block a funny braking when pushed in all the way. Drove it this morning no lights but bad braking filled up the fluids but need to replace the rear pads what do you think
Old Oct 26, 2011 | 11:36 AM
rajun asian's Avatar
Same exact thing happened to me when I had the front A-arms installed. The shims that you use for the abs sensor have to be the right clearance or you will definitely have that kinda problem.
Old Oct 26, 2011 | 11:44 AM
gsxr600409's Avatar
Ok ill ck into the shims im getting a realignment right now bc I had to raise the car a lil. And going to get pads right after. Dam did realize the g35 had this kind of problems
Old Oct 26, 2011 | 03:19 PM
gsxr600409's Avatar
Ok got a realignment didn't fix the problem. Also got new rear pads on that didn't fix it so I snooped around the front hub and took the front sensors of and cleaned then also I stuck a rag in the slot where the sensor sat and spun the wheels to clean the surface. And that did the job for my g35 coupe braking is back to normal he'll yea lol
Old Oct 26, 2011 | 03:23 PM
Sweet! I remember when mine were effed up. All I could think was why couldn't I just leave it stock? Then when we got it figured out, we were like HELL YEAH! Lol. Glad to hear it's fixed.
Old Oct 26, 2011 | 03:50 PM
gsxr600409's Avatar
thanks man. that sh*** was a headace
Old Oct 26, 2011 | 11:00 PM
saltyload's Avatar
This has become an intermittent problem for me. The first time I freaked out, but eventually I was like...
By the way, how did you fix it?
Old Oct 27, 2011 | 06:42 AM
Blue Dream's Avatar
I drove ttrank's car solo
Obviously reading > you.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
MsFitFern
Aug 9, 2015 02:58 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
