Will this 17'' oem wheel fit on 03 g35 coupe with brembo
Old Nov 3, 2011 | 04:10 PM
ureiken's Avatar
Hi,
Does anyone know if these wheels fit on 03 g35 with brembo? Does it clear the brembo without running spacers?
Thank you
Attached Thumbnails Will this 17'' oem wheel fit on 03 g35 coupe with brembo-g35w.jpg
Old Nov 3, 2011 | 04:11 PM
bluedevils95's Avatar
I believe 18 is to clear them.
Old Nov 3, 2011 | 04:17 PM
ureiken's Avatar
I know the the oem 18 clear them, my question was the 17'' as seen on the picture clear brembo?
Thank you
Old Nov 3, 2011 | 05:16 PM
ThatOneDude's Avatar
I believe his statement was to indicate that 17's do not.
Old Nov 3, 2011 | 05:19 PM
AzuMaster's Avatar
No they won't.
Old Nov 3, 2011 | 05:55 PM
ureiken's Avatar
If I run spacer will it fit?
Thank you
Old Nov 3, 2011 | 06:02 PM
AzuMaster's Avatar
The issue isn't the offset of the wheels unless you run a spacer so aggressive you clear the entire caliper which will have your tires sticking way out & will mess up your handling. The issue is that the calipers are too large for 17" rims/wheels. You need 18s at a minimum
Old Nov 4, 2011 | 01:14 PM
ureiken's Avatar
Thank you, very helpful
Old Nov 4, 2011 | 01:47 PM
Cant you just get different wheels to clear them?
Old Nov 4, 2011 | 02:17 PM
Jaxon1023's Avatar
Yes they will. There is a thread on here where someone did it. I'll try to find it.
Old Nov 4, 2011 | 02:21 PM
You can always test fit it on a friends car. Or i can try to find out by my friends
Old Nov 4, 2011 | 03:58 PM
Jaxon1023's Avatar
Here you go
https://g35driver.com/forums/wheels-...questions.html
Old Mar 6, 2014 | 12:53 PM
The_Silencer's Avatar
I have 17x7 sedan wheels that look exactly the OP's. Does anyone know for sure if they can clear Brembos?
R350k5
Oct 1, 2015 08:41 PM
teamghost
Jul 28, 2015 04:52 PM
mushu
Jul 15, 2015 03:55 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
