Quick tire help
Old Nov 7, 2011 | 11:54 PM
crazynuts16's Avatar
Quick tire help
My current setup is 225/45/18 in the front and 245/45/18 in the rear. Everything on stock 18's
I need to replace my front driver tire so i think i have a couple of options from the research i did and just need help finalizing.
1. Find 2 245/45/18 for the front too and have the same size all around?
2. Move the 245/45/18 to the front and put a wider tire in the back? and even after reading threads i don't really understand what size wider and what is the real advantage/disadvantage to going wide.
3. Leave 245/45/18 in the back and get 2 245/40/18 in the fronts?
oh and i am using used tires for now till i can afford new tires over the summer
thanks for your help
and if anyone has alternate suggestions i would be grateful
Old Nov 7, 2011 | 11:57 PM
4DGS's Avatar
Option 1 is best.
2 is ok, but you can't really fit anything wider on that 8" wide wheel out back... so no.
3, no that will put you the same as you are with a smaller tire up front.
Ideally, you should have a 225/45 up front and 245/40 in the back.
But 245/40 all around would be my choice.
Old Nov 8, 2011 | 12:02 AM
Originally Posted by 4DGS
Option 1 is best.
did you mean 245/45 all around? or 245/40?
Old Nov 8, 2011 | 09:28 AM
gary c's Avatar
You can easily run the 245/45X18 back and front without issues. It also makes for a more stable/controlled ride at highway speed.
Gary
Old Nov 8, 2011 | 11:02 PM
will this setup work without issues?
255/40/18 in the rear
245/45/18 in the front
245/45/18 is getting really hard to find so need some alternatives
408G35Sedan
Feb 23, 2022 06:46 PM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Soumilg
Jul 18, 2015 12:33 PM
