Speedometer not working on 03 G35 Coupe
Old Nov 14, 2011 | 09:53 PM
moningi's Avatar
Hi Frns,
I just had a worst day ever. got back from an oil change (@ Midas) . was a bit raining outside. I notice that my speedometer is not working.. The needle shows zero mph. The needle showing the engine rpm is not working either (stuck at zero). I also noticed that these lights are ON
a) VDC OFF
b) SLIP
c) AT CHECK (Automatic transmission check)
d) Engine Oil Pressure
e) Check Engine light flashed couple of times and then disappeared completely.
f) The headlights were flickering quite a few times
g) The turn signal indicators are not lit on the dashboard.
I kept driving real slow to get to home. I started noticing sudden jerks. This got me real psyched. Please help me and let me know your suggestions. Am I in big trouble?
Dont know if this helps, but Prior to this incident, like most of 03' G35 Coupes, CD is stuck in the CD player, AC is stuck at auto 75F with fan set to AUTO, center console buttons dont respond, steering controls for audio dont work either. In the winter/snow, I have to disconnect my battery every nite to stop it from draining overnight.
The passenger side headlight went out too a few months back.
I am taking to the MIDAS again tomorrow and keeping my fingers crossed. (am really pissed with the Nissan/Infiniti cars). Could you please let me know of your thoughts or share your experiences.
Thanks
Manoj
Old Nov 15, 2011 | 01:01 AM
partyman66's Avatar
Check for blown fuses both on the fuse box inside the cabin and also on the one attached to your positive battery terminal.
Old Apr 23, 2012 | 07:59 PM
pantspopo's Avatar
Hey
moningii have most of the same problems let me know if you figure this out!
Old Jan 14, 2019 | 10:53 AM
izzy_grayson's Avatar
5 Year Member
same here, anybody figure it out?
Old Jan 15, 2019 | 08:19 AM
Blue Dream's Avatar
I drove ttrank's car solo
Did you check the fuses suggested above?
arora_g35
Apr 16, 2026 02:52 PM
mike730
Jan 12, 2018 04:25 PM
R350k5
Oct 1, 2015 08:41 PM
Frostbite91
Jul 27, 2015 05:25 AM
attarday
Jul 15, 2015 04:03 PM
