Help Knocking sound when turning left or right
Old Nov 15, 2011 | 06:22 PM
westbank23's Avatar
Lately I've been hearing a knocking sound when turning left or right.it's starting to get louder and it only happens when I'm turning my stearing wheel while parked or slowly(2-5mph)or reversing.it sounds exactly like a front wheel drive car with a broken cv joint.
Anyone here experienced this problem before or could guess what's causing this?
Thanks
Old Nov 15, 2011 | 06:27 PM
maDUECEgunner's Avatar
most likely, one or more of your CV joints are going bad
Old Nov 15, 2011 | 06:32 PM
westbank23's Avatar
Yea but do rear wheel drive come with cv joint?
Old Nov 15, 2011 | 06:54 PM
oh wait, never mind, I have heard that its the bushings on some g35s
Old Nov 15, 2011 | 06:55 PM
juan350gt's Avatar
bushings or bearings have them checked.
Old Nov 15, 2011 | 07:51 PM
moto_za's Avatar
Does it happen between 2-3 rpm?
Old Nov 15, 2011 | 08:01 PM
westbank23's Avatar
No for instance if im pulling in or pulling out of a parking space while turning my steering wheel it will start knocking(only while turning the steering wheel at really low speed).also i think I need an alignment as well because my car will veer off to the right when I let go of the steering wheel(this happens all the time).
Old Nov 16, 2011 | 06:54 AM
Snakes' G's Avatar
I'd put my money on the inner lower control arm bushing.
Old Nov 16, 2011 | 11:51 AM
westbank23's Avatar
Ok so I was looking to replace my bushings with some whiteline bushings but I see that they have a bunch of different bushings.my question is sence my lower control arm is going to be removed inorder to install the new bushings in the inner lower control arms what else bushings should I get installed in that same control arm while I'm at it?
Old Nov 16, 2011 | 12:00 PM
faiz23's Avatar
Compression rod bushing
Lower Control Arm bushing to frame
Lower Control Arm bushing to shock
Old Nov 16, 2011 | 07:31 PM
moto_za's Avatar
Amazon Amazon
I had the same issue. I just ordered this and Amazon was the cheapest place. I still have to install it.
Old Nov 16, 2011 | 10:08 PM
westbank23's Avatar
Damn that's cheap!!
Is that all the bushing for the front suspension?lower,upper control arms,and compression rod bushings?
Old Nov 16, 2011 | 10:23 PM
jutn35's Avatar
G35 Coupe
compression rod ?
Old Nov 16, 2011 | 10:50 PM
westbank23's Avatar
Originally Posted by jutn35
compression rod ?
https://g35driver.com/forums/g35-cou...-bushings.html
chinee
Jun 10, 2024 07:48 PM
rping
Jul 26, 2015 09:53 PM
Thaaa_king
Jul 18, 2015 05:56 PM
