Recommended Tire Rotation
Old Nov 16, 2011 | 04:43 PM
Jiggyfingers's Avatar
What is the recommended mileage between tire rotations on our car?
I am also aware we cannot rotate from front to back due to size differences. I just want to know how many miles you have b4 you guys start rotating/inverting your tires.
Thanks...
07 Coupe
Old Nov 16, 2011 | 06:30 PM
rimshaker's Avatar
Like you said, we can't rotate the traditional way. But you can swap side to side if you have asymmetrical tires. I usually rotate other cars at every 5000 miles, just to use a nice even number.
Old Nov 16, 2011 | 10:41 PM
crazynuts16's Avatar
I would do it every other oil change pretty much. that is assuming that your doing oil changes every 3-4000 miles.
Old Nov 16, 2011 | 10:44 PM
MADtotheA's Avatar
What do you guys get charged to flip your tires? I had to pay $30 per tire...
Old Nov 16, 2011 | 10:53 PM
$30 :O
The standard rate in socal is 10 for dismount, mount and balance per tire, so if you do 2 they charge you 20.
regular rotation for all 4 is 10.
now the shop i know, i pay 15+5tip for mount/dismount/balance for 2 tires and checking alignment for free too.
Old Nov 16, 2011 | 11:14 PM
MADtotheA's Avatar
Well, time to find a new shop lol. Although I don't do this often at all..
Old Nov 17, 2011 | 08:40 AM
gary c's Avatar
The way my Michelin's are designed I can't swap em. They're wearing perfectly and my alignment is dead nuts to factory specs. Apparently you guys that change tires every oil change don't have directional tires that have arrows pointing the direction of rotation along with the words outside on the sidewall.
Gary
Old Nov 17, 2011 | 09:10 AM
nogoodname's Avatar
Just flipped my tires from side to side after 15k miles lol.
Old Jan 3, 2012 | 05:34 PM
Jwms's Avatar
Is there any problem with the old traditional flip across diagonally rotation on a sedan if the tires are ok with it? I have done this on most of my vehicles for years with no problem, but I see I the G-35 manual, it says to keep the tires on one side only...
jsimonk
Dec 22, 2023 03:49 PM
willdogs
Dec 8, 2015 11:32 AM
Jiggerjuice
Oct 5, 2015 02:33 PM
multimut
Canada
Jul 26, 2015 08:43 PM
Soumilg
Jul 18, 2015 12:33 PM
