need plexi glass 3/4 thick!
Old Dec 26, 2004 | 09:07 PM
chester's Avatar
Any one know where i can get a 3/4 inch plexi glass about 1'x1' jacksonville or gainsville or somewhere around there. PLS HELP!!!! ASAP
Old Dec 26, 2004 | 09:54 PM
neffster's Avatar
If I was at work I could help you as I've dealt with 2 plexiglass manufacturers in the past (although I don't remember if either was in FL). Try searching google for "aircraft plexiglass" or "plexiglass cockpit" and see what pops up. I got a sheet of 1/2 inch, 4' x 10' for about $100-ish if I remember correctly...
Also, you have mail in 5 minutes...
Old Dec 26, 2004 | 10:04 PM
neffster's Avatar
Well you can buy it from this place... USPlastic but it isn't cheap.
Also, search under polycarbonate... Many aircraft manufacturers and large aquarium manufacturers use plexiglass this thick. Also, apparently it's used for making speaker enclosurers... Good Luck!
Old Dec 26, 2004 | 10:08 PM
WRAH's Avatar
WRAH
I know I'm not in your area, but look up every glass/glass cutting companies. I work w/ alot of plexi w/ my models and your mom&pop glass companies a lot of the time can get you cheap plexi.
My suggestion is get out the phone book.
Old Dec 26, 2004 | 11:09 PM
KPierson's Avatar
Very expensive!
http://www.selectproducts.com/html/frame2/frames2.htm
Why do you need 'glass so thick?
When you use glass that small (1'x1') you can get away with using thinner glass.
I built this box a few years back: http://www.angelfire.com/oh2/pierson...mages/box1.jpg
It had (5) 12" speakers in a diamond config. The back sub was mounted in 3/16" glass! The 'glass never broke. Keep in mind this was a ported box so there would be less pressure on the inside of the box. Had it been a sealed box I would have went with 1/2".
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
9tray turbo
Sep 29, 2015 10:22 PM
miata007
Aug 17, 2015 04:36 PM
