HELP NEEDED: G35 coupe "External temp" sensor
My fellow riders.. I've searched with no luck. Can anyone tell me where exactly is the external temperature sensor is located on a 2005 G35 Coupe?
Mine has failed last night and the temp constantly shows 130F. Some search results show that it is located between the front bumper and radiator, others show under the windshield
(The first result makes more sense) but i just want to make sure before i started looking around.
THANK YOU
(The first result makes more sense) but i just want to make sure before i started looking around.THANK YOU
http://infiniti.sewellparts.com/oem-...oupe-2005.html
Part #27760
Looks like its underneath the radiator. I think its below the hood latch but idk. Thats all I got
Edit:
Read all of this:
https://g35driver.com/forums/g35-sed...re-sensor.html
Including the part about the reset.
Part #27760
Edit:
Read all of this:
Look directly behind your grill and you will see the hood latch, continue to look behind the grill and slowly turn your head to the left and you will see it. Its black with a very small nipple on the end of it
laksjd84
Jul 24, 2015 05:12 PM
stay_tuned
Jul 21, 2015 07:09 PM
Thaaa_king
Jul 18, 2015 05:56 PM
