help! losing power
Old Dec 22, 2011 | 07:24 PM
luisp88's Avatar
help! losing power
so recently my car doesnt feel as fast then before, the only engine mod is a jwt intake which i had for about 2 years. i cleaned the intake filter and had the spark plugs changed today thinking that it would help it. Also i did reset the ECU and Accelerator Pedal Release Position Learning. i have also noticed that the noise from the intake is significantly louder than before. Also there is no sign of transmission slip. the only thing i noticed when i was losing power is when i started hearing the intake louder than before.
car specs:
2004 g35 coupe
automatic transmission
87k miles
everything stock except for jwt cold air intake
thanks and happy holidays
-luis
Old Dec 22, 2011 | 07:43 PM
thepro78's Avatar
car specs:
2004 g35 coupe
87k miles
-luis
Check for an Air leak. Try putting back the OEM intake to see if it changes.
I experienced this with my mustang. Turns out I blew the welding on my intake Manifold... But I raced the crap out of that car...
Old Dec 22, 2011 | 10:25 PM
MADtotheA's Avatar
+1 for air leak.
Old Dec 22, 2011 | 10:49 PM
luisp88's Avatar
thanks for the replies,where would be key points to check on the engine?
-luis
Old Dec 22, 2011 | 10:58 PM
MADtotheA's Avatar
Check connection from intake pipe to your throttle body and also to the rubber hose connecting to your intake pipe. I'm guessing you have the stock g tube still...
Old Dec 22, 2011 | 11:04 PM
luisp88's Avatar
thanks,
i have the stillen tube which is similar to the z tube.
Old Dec 22, 2011 | 11:15 PM
MADtotheA's Avatar
thanks,
No problem. But yea, check that rubber hose beneath the stillen tube. I suspect it may not be fastened correctly.
Old Dec 23, 2011 | 10:57 AM
luisp88's Avatar
so this morning i took a look at the engine and especially at the intake. i took everything apart and looked closely for any leaks. i couldnt find anything and i was careful to reinstall everything back together, i even had a chance to look at the throttle body and it looked clean. i dont know what else to do someone please help.
-luis
Old Dec 23, 2011 | 11:01 AM
luisp88's Avatar
the intake noise is louder when im driving above 3k rpms but when idle and give it some revs it isnt there.
Old Dec 23, 2011 | 11:04 AM
MADtotheA's Avatar
Did you throw the stock intake back on to rule out the pop charger? Or is that not an option?
Old Dec 23, 2011 | 11:07 AM
luisp88's Avatar
i do have the stock intake. i will try that.
Old Dec 23, 2011 | 12:01 PM
luisp88's Avatar
i swapped the intake to the stock one, its not so loud but still feels underpowered. my brother says it sounds like something is clogged also when it shifts it shifts at about 5-6k rpms at full throttle
Old Dec 23, 2011 | 05:19 PM
luisp88's Avatar
anyone? please help
Old Dec 23, 2011 | 05:29 PM
MADtotheA's Avatar
Hard to say since none of us can see your car. If its a substantial loss in power then go have your mechanic look at it. If it wasn't the intake, it could be almost anything.
Old Dec 23, 2011 | 05:50 PM
luisp88's Avatar
yea thats what im going to have to do but i got to wait for the holidays to be over. i hope its nothing major, i never really had a problem with it. thanks for the help
