Problem with Spoiler LEDs
Hi Gang,
I own a black 2004 Coupe with the aero package. I am on my second dealer installed spoiler because some of the LEDs burnt out on the first one. I was just informed today by a co-worker that a few of the LEDs were out now on the new one??? Is anyone else having this much trouble with the spoiler LEDs?
Look forward to seeing if this is a widespread issue or just my luck.
Thanks.
Thanks.
are these after-market spoilers???
you can check by seeing if you guys have underbody air diffusers... factory spoilers are only installed with underbody air diffusers, as a package...
you cna also check to see if you have a fourth brake light, the one in the rear deck in your back seat, if so, then your spoiler was installed after it came form the factory, and more chances of it being aftermarket...
Originally Posted by spring42
Hi Gang,
Thanks.
Thanks.
Explain that you'd like a new spoiler if the problem persists. It could be the wiring.
G/L
mine was the OEM package(-the aero) im having it looked at by the dealer on monday. i'll keep you guys posted how it turns out.
Originally Posted by jaay11
Darn....
Having a spoiler installed on Thursday by the dealer....just the spoiler. Should I be concerned if I do not have the underbody air diffusers?
Originally Posted by gnut
Hey guys, what do the diffusers look like and exactly where are they installed? Can you tell the difference between the OEM and aftermarket spoiler by just looking at it on the outside?
I know this because last January, when I was buying my car, the dealership tried to push an aftermarket spoiler and I refused because there was a visible difference and the warranty was only 12 months. When I walked the lot, I saw several after market spoilers installed and several OEM spoilers right beside them. The differences are visible.
