Cowel Panel
Cowel Panel
Does anybody have any clue how to install these? my car has the LH so i ordered the RH and it seems like it doesnt fit... does the RH go kinda under the LH? or how does it work ill post pics tomorow its too dark outside right now the RH peice came from an 07 will that make a diffrence? Thanks.
the pass side sits over the end of the driver side. start it in on the far pass side first making sure the edge of the windshield slips into the slots of the cowl. Then work your way with it toward the drivers side and the hole in the end slips over the tit on the end of the drivers side cowl. Don't forget the washer fluid line attaches to the bottom of it after it's installed.
So after and Hr of trying to put this thing on.... I figured it might not be the right peice... Can anyone confirm it? please. its sopose to be RH Cowl panel for the coupe. but it seems like its too long and overlaps the LH Thanks..it came off an 07. mine is a 06
Turns out its a sedan peice... and i cant find a Coupe peice whats worse case scenario if i leave it like that for now.. how would it do in the rain? ill put a cover for the cabin filter but would it have a mass effect since the battery is there?
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
leo38cheng
Sep 29, 2015 05:43 PM
