Unplugging Maf sensor
Old Dec 31, 2011 | 05:02 PM
allblackcoupe's Avatar
I unplugged the maf sensor without taking the neg terminal off the battery, would that cause it to go bad? I just did my spark plugs and my engine is missing and my cel is on. I didnt use platinum, could that be why?
Old Dec 31, 2011 | 05:07 PM
partyman66's Avatar
Unplugging the MAF sensor without disconnecting the battery wouldn't do anything to ruin the sensor. It could be the plugs, but the easiest way to find out the problem is to hook up to an OBD-II scanner and pull the code to find out what's wrong. Auto Zone will do this for free for you, except if you live in Cali (for some strange reason they don't do it in Cali Auto Zones). If the engine is misfirig, it could be that you used the wrong plugs or that one (or more) of your plug wires isn't fully seated on the plug.
Old Dec 31, 2011 | 05:14 PM
superchargedg's Avatar
Make sure all the coils electrical connectors are plugged in tight and that the coils are fully seated...if they are you might have closed the gap of one of the plugs.
Old Dec 31, 2011 | 06:57 PM
AHA! i fixed it, it was a bent pin on one of the coils! it was throwing the p0300 code
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
