View Poll Results: Wheel Size G35 coupe
19x8.5 F 19x9.5 R
13.33%
19x9 F 19x10 R
13
86.67%
Voters: 15. You may not vote on this poll
Opinions on wheel sizes
Old Jan 26, 2012 | 10:51 PM
davidblak3's Avatar
I'm stuck between wheel sizes and needed opinions
Option A
19x8.5 Front 19x9.5 rear
Option B
19x9.5 Front 19x10.5 Rear
Old Jan 27, 2012 | 02:13 AM
bluedevils95's Avatar
Wider is better
Old Jan 27, 2012 | 02:16 AM
DBrann's Avatar
20x10.5 all around.
Old Jan 27, 2012 | 02:35 AM
^^ WOW!!!! That is intense
Old Jan 27, 2012 | 09:42 AM
jstudrawa's Avatar
It depends on what tire sizes you put on them, as well. Can't have one without the other, and tires affect the look just as much.
Old Jan 27, 2012 | 09:52 AM
redpearl99's Avatar
9.5 is too small for a coupe rear
Old Jan 27, 2012 | 10:01 AM
Jhambor's Avatar
Originally Posted by DBrann
20x10.5 all around.
^^^^This!!!
Old Jan 27, 2012 | 10:29 AM
walshtj's Avatar
B def out of those two options. What wheels are you thinking of going with>
Old Jan 27, 2012 | 11:00 AM
redpearl99's Avatar
I still think you should be going wider than 10 in the rear
Old Jan 27, 2012 | 11:23 AM
davidblak3's Avatar
I'm putting some light weight wheels on TSW makes a set of wheels called the Nurembergring rings that weigh 22.4 in the rear and 22/4 in the front they are also forged wheels and they only come in half sizes so 19x9.5 in the front 19x10.5 in the rear
TSW also makes the interlagos and they are a little lighter weighing 23.5 in the rear and 21.5 in the front
Old Jan 27, 2012 | 11:36 AM
flyz's Avatar
Go wider.
What offsets do those come in?
Old Jan 27, 2012 | 07:03 PM
davidblak3's Avatar
Looks like for the rear wheels 19x10.5 the offset is +27
for the front wheels 19x9.5 the offset is +41
Old Jan 27, 2012 | 11:28 PM
gary c's Avatar
Originally Posted by davidblak3
Looks like for the rear wheels 19x10.5 the offset is +27 for the front wheels 19x9.5 the offset is +41
David these offsets....^.... are wrong! Guaranteed if you use 40 offsets in front your wheels will rub inside on tight turns causing you to lose control....I should know happened to me! Buy wheels 19X9.5 (f) and 19X10.5 (r) with low to mid 20s offsets, you won't need spacers and they'll fit perfectly. Tire sizes can be 245/35s (f) and 285/35s (r).
Gary
Old Jan 27, 2012 | 11:32 PM
^ 245 on the front? That going to be stretching a little bit. I stretching very little w/ 255
Old Jan 28, 2012 | 01:44 AM
redpearl99's Avatar
245 shouldnt be that much of a stretch at all
