Rev Limit Help please!
Old Jan 29, 2012 | 07:00 PM
Oklahomie22's Avatar
I have an 06 G35 coupe, and today I was in 2nd gear and accidentally revved my car up to 6500rpm (ish, around that) and was scared for my life for a second, then switched to 3rd and everything seemed to be fine as I finished my drive home, I even turned my car off and back on to see if anything sounded different but everything seemed ok. Is my car ok if this is the first time it has gotten this high? Any help is greatly appreciated. Thanks!
Old Jan 29, 2012 | 07:15 PM
redpearl99's Avatar
Your car is fine
Old Jan 29, 2012 | 07:23 PM
Nickefer's Avatar
Is this a serious thread?
Old Jan 29, 2012 | 07:25 PM
yea man, I really dont know a lot about cars, and I love my G. So I am just making sure she is okay. So I take that as its ok to do every now and then accidentally? hah
Old Jan 29, 2012 | 07:31 PM
herrschaft's Avatar
There is a rev limiter for a reason. The engine will not miraculously blow up if you hit redline a few times.
Nickefer's Avatar
The only thing hurting is your gas mileage...
Your car a rev limiter which will keep it from revving high enough to cause damage. Now dont go driving around bouncing off the rev limiter all the time but to answer your question hitting 6500 is no big deal, I prob hit it a couple time a day having fun in my car
Old Jan 29, 2012 | 07:52 PM
redpearl99's Avatar
actually, I take that back, turns out your car is not fine if you it 6500 RPM....you're going to need to change your headlight reflector fluid
Old Jan 29, 2012 | 09:30 PM
LoSt180's Avatar
You have an 06 6mt, and ONLY hit 6500 rpm? You realize your redline is 7200 on that engine? Set your shift light to 6800 or so if you're worried about over reving.
Old Jan 29, 2012 | 10:00 PM
iiiiiekoiiiii's Avatar
my car prbly saw 6500rpm good 6500times over years.
Old Jan 29, 2012 | 10:41 PM
GinVB's Avatar
Originally Posted by redpearl99
actually, i take that back, turns out your car is not fine if you it 6500 rpm....you're going to need to change your headlight reflector fluid
LOL yep
Old Jan 30, 2012 | 12:28 AM
Songle6MT's Avatar
6500 is laughable.
Nothing to be worried about.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
