Set Engine to Factory Specifications
Old Jan 30, 2012 | 11:34 AM
Hybryd40's Avatar
As the title says. I was at the Infinity dealer the other day and they offered this service on the wall for 89.95. Is this something that actully needs to be done? If so starting at what kind of mileage. I am assume this consists of adjusting the valvetrain. Is this correct?
Old Jan 30, 2012 | 11:40 AM
Songle6MT's Avatar
Any details on what the service was? Just stating there was a service for 89.95 leaves a whole lot of room for interpretation/guessing.
Old Jan 30, 2012 | 11:44 AM
Hybryd40's Avatar
Set Engine to Factory Specifications that is what they called their service.
Old Jan 30, 2012 | 11:52 AM
Hybryd40's Avatar
I just called and its just a way to con someone out of their money. They reset the base timing and idle to factory spec. I do all my own service but when I was picking up a part this caught my attention = )
Old Jan 30, 2012 | 12:44 PM
Footballmania32's Avatar
Smh........ InfintiI with an I!!!!!!!!!
Old Jan 30, 2012 | 01:44 PM
Songle6MT's Avatar
Yeah definitely seems like a good way to spend 90 bucks
Old Jan 30, 2012 | 06:12 PM
MrTiToG35's Avatar
Originally Posted by footballmania32
smh........ Infintii with an i!!!!!!!!!
and without the "L"
Old Jan 30, 2012 | 06:31 PM
partyman66's Avatar
There's nothing magical they're going to do for you for $90 on your motor that you can't do yourself for free and isn't typical maintenance(oil, etc). If there was, it would be more invasive, such as taking off the valve-covers and adjusting lifters, etc. in which case they'd be more likely to charge you about $800 for the service.
They probably just reset the ECU, and you can do that yourself by simply following the ECU factory reset procedure which just involves a series of presses on the gas pedal and turns of the ignition key. You shouldn't need to do that though, since that will just cause the vehicle to relearn your driving tenancies... which it does anyways on its own over time.
Old Jan 30, 2012 | 08:08 PM
gary c's Avatar
The stealerships have figured out just one more way to screw their customers. It takes no more than 2 minutes to reset the OE paramiters in the ECU kinda like dialing a number on your cel....
Gary
Old Jan 30, 2012 | 09:48 PM
bigc's Avatar
Wings Nation
Disconnect your battery, hit the brake pedal three times, reconnect your battery, then paypal me $50
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
D1dphresh
Aug 7, 2015 06:10 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
TWASkyliner
Aug 1, 2015 11:43 AM
