Help!!! Slave Cylinder not pressing fork all the way back
Old Feb 2, 2012 | 06:05 PM
Decode's Avatar
Angry Help!!! Slave Cylinder not pressing fork all the way back
So i replaced my Clutch and it was hard to get into gear , Id have to press it all the way down to the floor i drove it like that for 2 days thinking it would go away it got worse to where i would have to double clutch 2 days later . So i brought it to work ( Len Stoler Nissan i sell cars ) And i couldent get it in gear . We got it in the shop and thought it was the slave Cly so i replaced it still nothing it was only engaging half way and not pressing the fork all the way back but if we took a flathead we could assist the slave and get it to fully engage . I bought a master Cyl replaced that and its still not engaging all the way !!
Help me , I have no clue whats next..
Old Feb 2, 2012 | 07:00 PM
robfisherg35's Avatar
Sounds stupid... But check and see if the arm is bent?
Old Feb 2, 2012 | 07:59 PM
Decode's Avatar
No its not i just checked.
Old Feb 2, 2012 | 08:07 PM
faiz23's Avatar
Check to make sure that internally the throwout bearing, fork, clip and everything was put back properly. Does not sound like a hydraulic issue and more internal to do with pressure plate, throw out bearing and fork/pivot ball.
Old Feb 2, 2012 | 08:27 PM
Decode's Avatar
Thats the thing if you push the fork with your hand the rest of the way it will go all the way back to engage
Old Feb 2, 2012 | 08:39 PM
GreenGoblin's Avatar
The goblin resurrection
Could still be air in the system. Also I have got factory defective nissan parts before. Also check that the master is adjust correctly. Did you bench bleed it before putting it in the car?
Old Feb 2, 2012 | 09:21 PM
AreSicks's Avatar
Check to make sure the pivot ball didnt break? Make sure it is actually pivoting and not hitting the trans case and pivoting off of that.
Old Feb 2, 2012 | 09:59 PM
Decode's Avatar
My friends a mechanic at my dealership he did all of that ... ugh
Old Feb 2, 2012 | 10:06 PM
AreSicks's Avatar
And you have pedal pressure all the way through the travel of the pedal?
You could take the slave off and make sure it has full travel as someone presses on the clutch pedal. Just make sure you dont pop the piston out of it.
Old Feb 4, 2012 | 09:53 AM
Decode's Avatar
So i found out the person who did my clutch did not put a new throwout bearing in , Would this cause the clutch to stick and the slave not able to press the fork all the way back ?
Old Feb 4, 2012 | 12:34 PM
AreSicks's Avatar
What clutch did you put in? Some clutches do not use the factory throwout bearing. It might not be compatible with the clutch you have. Anyone dumb enough to go through pulling the trans and not change the throwout bearing probably installed the clutch wrong too lol.
Old Feb 4, 2012 | 05:00 PM
Decode's Avatar
It was an exedy kit and it only came with the throw out bearing , The guy who did my clutch never pulled the flywheel off so its not possible he replaced the pilot bearing .
Old Feb 4, 2012 | 05:33 PM
AreSicks's Avatar
Pilot bearing shouldn't cause any symptoms you are describing. So did the throwout bearing get replaced or not? If it did get replaced, I would say its installed wrong (if you're sure the hydrolic system is bled properly). It would be almost impossible to get a clear view if the throwout bearing when the trans is installed to see if it's in their properly.
Old Feb 6, 2012 | 11:31 AM
Decode's Avatar
Whats the properway to bleed ? My Service Tech's did it " Len Stoler Nissan " and they said they had trouble getting the slave to keep pressure and push the fork more then halfway back . They said if they took a flathead they could assist the slave and press the fork all the way back , We replaced the Slave And Master and there was only a slight change " I can acutally drive it now just the pedal sticks and i have to rev up around 3k to get it come out ..."
Old Feb 6, 2012 | 12:05 PM
AreSicks's Avatar
You can try a different method of bleeding from how you do brakes. Pump the clutch pedal for 30 seconds or so. With the clutch pedal UP, open the bleeder. Press the pedal to the floor quickly and close the bleeder. Repeat. Once you start getting better pedal pressure you can go back to the brake method of pumping the pedal, holding it to the floor, then opening and closing the bleeder.
