Front wheel bearing replacement
i had to replace my rear wheel bearing on my 03 coupe, the bearing alone was 90$ from carquest auto parts the hub is 150$, the thing is if ur hub is warped or damaged in anyway it could ruin the new bearing, if u have a good mechanic or if your doing it yourself, u can use the old hub but make sure the hub is in good condition and installed correctly. i replaced my bearing with the old hub and my bearing hasnt worn down and is still works fine. i did the repair about 6 months ago. But being tht it was the rear and not the front it could be a slight difference. just make sure whoever does ur repair tht they check the condition of the old hub before they install the new bearing
There is a difference (not a slight difference either) between the front and rear hub assemblys. If your going to condradict someoene make sure you know WTF your talking about first.
Back to my previous statement that the wheel/hub assembly are a single unit.
You can verify it with factory service manual.
I drove ttrank's car solo
Received 1,486 Likes
on
^^Before you go all commando on someone make sure YOU have your facts straight. You can purchase the bearing and hub separately from any Infiniti or Nissan dealer. Now, I would recommend replacing both at the same time, but that doesn't change the fact they are available separately.
Remember the saying, People in glass houses......................
Example of a bearing sold separately: http://www.ebay.com/itm/40210-2Y000-...#ht_500wt_1362
And the hub by itself so there are no questions here: http://www.ebay.com/itm/40202-24U00-...#ht_500wt_1362
according to HODRodG35 i dont know what iam talking about..Richboy has money for all those mods and repairs.he dont need to budget.....Right its recomended to replace both, but if your short on money u can just repalce the bearing, just make sure whoever does the repair knows wht hes doing. and tht your hub is in good condition. thanks for the support blue dream
Just replace the whole hub, it's a remove/replace deal. If you can change rotors, you can change the hub.
I'm not sure if the tone ring (for ABS) is built into the bearing or the hub, but I imagine it would be easily damaged trying to press out a bearing. I had to replace mine when a shop damaged the tone ring installing the SPC camber shims. There's a guy selling one right now for $100 on Craigslist (Wash, DC).
I would imagine that if it was possible to press in new bearings somebody here would have done so already. I think Ill swap out the damaged side with a oem assembly then check if theres a part number on the old bearing unit and cross reference it. Most mechanics i work with tell me that any bearing unit can be replaced with the right tools it u have the part number for the actual bearing. Ill give it a go and post back on the results. Id imagine a bearing alone would be about $50 to $75 vs a hub assembly at $150. Thank u to all who replied here so far. U guys are great.
If your going to do a comparison ensure its for the proper application.
Watch out for broken glass !
Not going to deny making a comfortable living. I've worked for everything I own. Bicycles were only mode of transportation parents ever bought for me growing up. Paid for every car including insurance and gas.
Dont pay for repairs and maintenance on vehicles that I can do myself. I've done 95% of the mods on my car, rest was done by others because of the equipment or skills.Build thread coming soon after done with many never before seen mods on a G35/350z.
Check out CUX350z thread "Ditched Vortech for Greddy TT" on my350z forum. That was done by Chris & myself in my garage.
on
Glad you chimed in with more misinformation. You should get your facts straight before going on a quest to prove someone wrong. The parts referenced from EBay are for a G35X ( and I-30/I-35) which I agree you can change individually. EBay seller did a poor job of describing application.
So you really want to argue semantics? The same parts are available for 2WD sedans, coupes and 350Zs. Just call any Infiniti or Nissan dealer, hit up Phil@Grubbs, or search ebay. I won't do the work for you as I have nothing to prove to you, I'm right so deal with it. No need to be a DC.
I contacted the following parts stores:
Bradshaw Infiniti
Benson Nissan
AutoZone
Advance Auto Parts
CarQuest
NAPA
O Reilly's
Those are all the major stores in my area, everyone contacted said the front wheel bearings is sold as hub/bearing assembly because the bearing is sealed and ABS sensor is mounted to hub.
So your half a$$ed search on EBay for the incorrect parts was a failure. Your right ? WRONG D BAG!!!!!!
Semantics ? its the principal that you feel its okay to pass along bogus info and not able to back it up.
Man up and take responsibility for your mistakes.
Fatlip turned to the G35Driver community for help and people like you supply BS for an answer.
on
Wow great rebuttal, Are you a Lawyer ?
Bradshaw Infiniti
Benson Nissan
AutoZone
Advance Auto Parts
CarQuest
NAPA
O Reilly's
Bradshaw Infiniti
Benson Nissan
AutoZone
Advance Auto Parts
CarQuest
NAPA
O Reilly's
Since I have no desire to argue with you let's just say you win. Feel better?
Hopefully this may help to clear any confusion regarding the hub/bearing.
This is for a 2WD models. so all V35 coupes and sedans.
As the schematics show, the hub and bearing are one unit.
The part number for the unit is 40202-AL56C
Attachment 148214
Attachment 148214
ErikNYC (09-15-2017)
