(Electrical Problem) - Infiniti g35 Coupe - Dash Flickering?
Old Feb 12, 2012 | 03:45 PM
austsmt's Avatar
I just bought a 2005 Infiniti g35 coupe. Has 35,000 miles on it. Ok so, this morning when I turned my car on, the dash was all flickering. Like where it shows the temperatures. Also the little lights in the buttons on my dash were all flickering. About half way to work the flickering stopped. After worked I turned it on and it wasn't flickering..so I have no idea what's happening. I live in Florida, but this morning it was 29 degrees Fahrenheit. Maybe it has something to do with the cold? I have no idea. If anyone has any clue what's going on, please post! Thanks
Old Feb 12, 2012 | 03:47 PM
Shanes_G's Avatar
you might have a bad ground.
Old Feb 12, 2012 | 03:53 PM
austsmt's Avatar
Bad ground? Um, what's that?
Old Feb 13, 2012 | 10:21 AM
austsmt's Avatar
Still looking for an answer, thanks!
Old Feb 13, 2012 | 10:27 AM
jrockstarr's Avatar
i believe he is referring to you battery connections
Old Feb 13, 2012 | 12:21 PM
Footballmania32's Avatar
Check your battery first. Its the most inexpensive route. I have a feeling it could be tjat.. And as Shane mentioned, check the grounding of your wires. I.e. wires bolted down to the frame and engine.
Old Feb 13, 2012 | 04:31 PM
TemjinX2's Avatar
could just be a dying battery.
Old Feb 13, 2012 | 04:37 PM
Frankieg35's Avatar
If u don't know what a ground is I suggest u take it to a professional..
Old Feb 13, 2012 | 05:40 PM
Teelux's Avatar
That sometimes happens to be when I have the dash LED brightness dimmed, but never when the headlights are on. It never flickers until the next morning, when my headlights are no longer on (set to auto). When I turn the dimmer dial back up to full, the flickering goes away.
Old Feb 13, 2012 | 05:51 PM
rozhenko's Avatar
if it was the battery, the car wouldnt start. check all the ground wires on the motor and the frame. or take it to a mechanic if u dont know what ground is lol
Old Feb 14, 2012 | 09:39 AM
austsmt's Avatar
Took it to a mechanic..they had no idea why it was flickering..car looks brand new cept for the belts..there both dry rotted from sitting in a garage for 5years. So going to have to get that fixed asap.
Old Feb 14, 2012 | 09:40 AM
austsmt's Avatar
I think this is what mine does.
Old Feb 14, 2012 | 11:55 AM
jonesmeister11's Avatar
this???
Old Feb 14, 2012 | 12:34 PM
austsmt's Avatar
Originally Posted by jonesmeister11
No.
Old Feb 15, 2012 | 07:52 PM
Teelux's Avatar
It's kind of annoying, but since I can stop it from flickering by turning the dimmer dial, I haven't bothered to get it dealt with.
