Advance timing
Old Apr 26, 2003 | 03:25 PM
Scoop's Avatar
Advance timing
Has anyone had any experience with advancing their timing?
If so who can do it & how much can it be advanced without doing harm
<font color=blue>[b]G35c DG/leather 5AT 18"wheels Tint.... The car in your mirror will fade quickly
Old Apr 26, 2003 | 03:31 PM
ryoken's Avatar
Re: Advance timing
I was under the impression that Infiniti already has the timing advanced to the ragged edge....
Old Apr 26, 2003 | 03:44 PM
Merlin's Avatar
Staff ALUMNI
Re: Advance timing
Computer controlled, so unless you have the CONSULT II tool you will not be able to do it.
Old Apr 26, 2003 | 04:44 PM
bliz's Avatar
Re: Advance timing
im thinking of getting this done to my sedan,do you advance the timing through the whole rpm band or just top end.sorry if this a stupid question.
Old Apr 26, 2003 | 04:45 PM
AntRock's Avatar
Re: Advance timing
i was under the same impression. for example my sister has an altima with the same engine, she has much less hp and she can use regular gas, if we used regular gas our cars would start pinging at WOT. our cars are pretty much tweaked to the capacity unless you get some kind of forced induction.
Old Apr 26, 2003 | 06:12 PM
D_Nyholm's Avatar
Re: Advance timing
Well, an Infiniti guy from Freshalloy advanced his 2*. It can go to a max of 5 but he figured that was safe....
<font color=red> Laser Red </font color=red> G35C 6MT Willow, Premium. Picked up on 11/27/02
Old Apr 26, 2003 | 11:27 PM
Merlin's Avatar
Staff ALUMNI
Re: Advance timing
No question is stupid, if you don't know ask.[img]/w3timages/icons/smile.gif[/img] Generally when you advance the timing at idle it affects the entire RPM range. But with computers controlling everything these days, this is not always the case. The reason is that, at any point in the RPM the computer can change fuel and ignition to match what the engineers programmed the AFR (Air Fuel Ratio) should be. Then you add in all the other sensors and on and on and on.......[img]/w3timages/icons/smile.gif[/img]
Old Apr 26, 2003 | 11:39 PM
RamboRami's Avatar
G35driver.com Moderator
Re: Advance timing
<h3>"There is no such thing as a stupid question.
Just stupid people, who ask questions."</h3>
<font color=green>-Ramb0</font color=green>
Old Apr 30, 2003 | 10:32 AM
hooknows's Avatar
Re: Advance timing
i just read an article yesterday on octane because alot of people on freshalloy think part of the 20hp difference between the coupe and the sedan has to do with the octane you can use in each car.
the article which came from the site howstuffworks said that higher octane must be used in higher compression engines, period. both the sedan and coupe and 350Z have the exact same compression ratio engines, which is 10.3
so, i don't know why you would be able to use a different octane on either car.
chinee
Jun 10, 2024 07:48 PM
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
