Car Dies~Help !!~
Old Feb 22, 2012 | 09:55 PM
xoxx's Avatar
Car Dies~Help !!~
I was driving and my car went into a "limp mode" style. All lights were on, slip and other dashboard warnings. Engine still running, but was idling. Gas would not make a difference, engine would just idle.
How can I trouble shoot this problem?
I am under the assumption it is an electrical thing?
Thanks for any help!!!
Old Feb 22, 2012 | 10:11 PM
bythabay's Avatar
Where are you located?
Old Feb 22, 2012 | 10:17 PM
diablo_cc's Avatar
Possible the throttle cable somehow came off, but I'm not sure what would 1) cause that, and 2) what other results that would give you other than the obvious 'not being able to produce any rpms other than idle while pressing the gas pedal'.
Old Feb 23, 2012 | 01:17 AM
xoxx's Avatar
To fix the issue I placed the car in park and then turned it off and back on. This makes me think that it is something electrical.
Old Feb 23, 2012 | 02:04 PM
xoxx's Avatar
I am in southeast USA.
Old Feb 23, 2012 | 02:30 PM
bythabay's Avatar
I am fairly certain your Throttlebody is bad..
Old Feb 23, 2012 | 05:05 PM
xoxx's Avatar
would the Throttlebody cause the car to go limp and all of the warning lights to turn on?
And if it were bad wouldn't I get the same problem 100% of the time?
Thanks
Old Feb 23, 2012 | 05:11 PM
bythabay's Avatar
yes
and if it were bad wouldn't I get the same problem 100% of the time? thanks
that's an interesting point - i don't know for sure
Old Feb 23, 2012 | 05:23 PM
diablo_cc's Avatar
What year/transmission is your car?
Old Feb 23, 2012 | 06:39 PM
xoxx's Avatar
I believe it is an 04, possibly early 05.
Thanks
Old Feb 23, 2012 | 07:24 PM
Keggr626's Avatar
I thought our cars used an Electronic drive by wire and didnt have a cable?
Old Feb 23, 2012 | 08:45 PM
superchargedg's Avatar
We do and he dosent know what he is talking about...but on to the problem.Your throttle body is bad and how do i know this...im on my 3rd one and had the exact same problem you describe.
Old Feb 24, 2012 | 02:10 AM
xoxx's Avatar
ok thank you for the help.
I got the service engine codes back and they say that the camshaft sensor is bad. Im assuming the broken camshaft sensor forces the computer to not allow the car to start.
So not the throttle body.. But thanks for the input
Old Feb 24, 2012 | 12:54 PM
lostangels01's Avatar
Yea sounds like you need to replace your camshaft sensors. Also it helps to clean your throttle body and air filter from time to time.
newg37
Jul 26, 2015 09:32 AM
Thaaa_king
Jul 18, 2015 05:56 PM
