crazy vibrations on the shifter 6mt normal?
Old Feb 25, 2012 | 06:22 AM
martyball619's Avatar
today i test drove a 6mt 05 g35 and the shifter vibrates like crazy.. is this normal for all g35s? or is there possibly something wrong with this car
Old Feb 25, 2012 | 08:00 AM
blackout2277's Avatar
Mine vibrates like crazy on my 04. Not saying its normal though... Idk
Old Feb 25, 2012 | 08:58 AM
eboelzner's Avatar
My 05 does to when the rpms get over 3500
Old Feb 25, 2012 | 10:53 AM
HYDRUS's Avatar
Normal. After an oil change it always seems to reduce tho
Old Feb 25, 2012 | 11:17 AM
Jhambor's Avatar
Your definition of crazy and mine may be totally different....so it's hard to say.
Old Feb 25, 2012 | 01:12 PM
destroid's Avatar
Some vibration is normal. It will also move around like 1/4 inch as you get on/off the gas. If you can't hear anything strange vibrating then it is probably fine.
Old Feb 25, 2012 | 02:40 PM
partyman66's Avatar
Mine only vibes when I'm in gear and let off the gas. It usually vibes a bit as the car slightly compression brakes and I usually get some sort of single big vibe about 1/2 a second to 1 second after letting off the gas. It's always done it, and I don't see it as a problem.
Old Feb 25, 2012 | 04:29 PM
saason.Ez's Avatar
mines the same.... then i tightened it and it was fine
Old Feb 25, 2012 | 06:05 PM
partyman66's Avatar
Tightened what?
Old Feb 25, 2012 | 06:25 PM
Jestered's Avatar
I personally don't feel an abnormal amount on mine. By abnormal I mean it's the same as any other MT car. It may not be anything to worry about, but I don't have that problem with mine.
Old Feb 25, 2012 | 06:53 PM
eboelzner's Avatar
[QUOTE=Jestered;6346379]I personally don't feel an abnormal amount on mine. By abnormal I mean it's the same as any other MT car. It may not be anything to worry about, but I don't have that problem with mine.
Mine at 3500 plus I'm sure was just me over analyzing it. It's been 10 years since Ive driven a mt...
Old Feb 25, 2012 | 07:07 PM
EnerOnE's Avatar
The shifter does vibrate just like any other stick shift. Maybe because that's the only thing that vibrates it makes it feel as if it is doing it pretty crazy....
Old Feb 26, 2012 | 12:44 AM
parhamm1's Avatar
What you're experiencing is 100% normal in the G. Nothing to be worried about. Just get used to it.
Jiggerjuice
Oct 5, 2015 02:33 PM
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
G35CO
Sep 4, 2015 09:27 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
