Projectors issue.
Projectors issue.
I just got my car back from getting work done on it and from what I understand the amp fuse keeps getting fried. Figured there wasn't enough power being sent to it, so went up to a 25a and everything worked fine. Everything got power, but later today it stopped working. I'm assuming it got fried again. I'm not really sure what I should do. Some advice on what I should do would be great.
something is grounding out...thats why you keep burning fuses. if you got a new stereo system installed, check all your amp and sub wiring. Check the wiring from the battery to the amp as well. Some thing is expose and is grounding out. Also check all your connections, something might not be connected all the way.
Learned Hand
Oct 1, 2015 09:02 AM
