TORETTO
close
- Join DateSep 2007
- LocationAuckland, New Zealand
iTrader Positive Feedback100
iTrader Feedback Score(18)
Liked:1,941 Times in 1,251 Posts
Quote:
got a new video with your current set up yet?Originally Posted by xXHotelCrazyXx
You guys are a lost cause... I am losing hope in this forum...
Quote:
+1000Originally Posted by leanlikeacello
i have at and didn't feel anything different after replacing mine :\
xXHotelCrazyXx
close
- Join DateApr 2007
- Locationfive oh two
iTrader Feedback Score(21)
Liked:221 Times in 121 Posts
Quote:
exhaust?Originally Posted by STAP IT
Quote:
Na, almost tho. You guys can pm each other. Keep it on point.Originally Posted by STAP IT
Thread was derailed on page 1. Post #5.
Lol @ GAU..
Your problem is you didn't get the duralast gold. Makes all the differnce..
lol. Na really, I wouldn't expect that you would notice something on your cars. I've replaced dozens of batteries in different vehicles. Only time I've ever noticed is now. Every car is different, some set up better than others. Probably a rare event either way.. How are you liking the grounding kit? I've got the itch to spend somethin' on the car these days. Actually considering the thought of gettin' one.
And oh, thanks for the line... Mwahahahaahhaha.
I bought the grounding kit simply for the 5AT. If it were a 6MT I would have passed. I think I got better results from the shift kit.
Oh, I never said I didn't get the Duralast, lol. I actually have the Duralast Gold in both cars. I only shop AutoZone for my little parts like that.
I'm sorry to resurrect this fairly old thread, but I can't *not* comment on one statement...
Fundamentally what xXHotelCrazyXx is saying is essentially correct in that the battery is only used to start the car. Contrary to what someone else stated, the alternator is producing DC power because it contains within it a power rectifier (AC-DC convertor) in the form of big diodes, plus a voltage and current regulator. The missing part in this discussion is that this type of AC-DC power convertor needs one crucial element to work correctly - a capacitor... and, guess what?... a battery is a giant capacitor in effect.
So, yes, a car can run only on the alternator and, yes, it can run only on the battery. But without both being present and working correctly, the electrical system can't either function for very long (on battery) or will be noisy (due to the lack of a capacitor to smooth out the DC voltage).
In the end, xXHotelCrazyXx and GAU-8 are both correct! I won't comment on the orginal poster's assertion however
Sunil
Quote:
False... power is *drawn* from the source, not pushed. So purely from a power systems perspective, the generator (alternator) may fail earlier when the battery is failed because it has *more* load on it due to a battery that draws more current but can't hold the charge. However, if the battery simply isn't there, there is no reason for the alternator to work harder, overheat and fail (but see next point).Originally Posted by GAU-8
... It's trying to charge the battery (that won't take a charge) so it heats up the internals since all that power has nowhere to go. Overheats - bam - premature failure.
Sunil
