Crack in dashboard
Mar 17, 2012 | 03:11 PM
Anyone else have issues with cracks in dash? Found this crack in my 07 AT. After searching around it seems like cracks in dash are rare for g35. Only thing I could find were issues with dash on FX35 model. I also have slight "bubbles/warps" on the passenger side of dashboard. Under certain lighting you can clearly see the "bubbling/warping", and you can feel the "bubbles" if you run your hand over the dash. I purchased the car in May 2011 and did not notice it until a couple months ago. Only time my car sees direct sunlight is when I'm parked at work.
Reply 0
Mar 17, 2012 | 03:15 PM
I don't have this problem and I have never heard of others having this issue. Maybe the previous owner(s) took apart the dash and wasn't to careful and fuked it up.
Reply 0
Mar 18, 2012 | 07:37 AM
crack dashbord
Finally someone have the same problem, my car is 2006 my dashbord is crack for over a year now .
Reply 2
Mar 18, 2012 | 09:40 AM
i just bought an 05 sedan flawless except for the dash that has a crack which i will post a pic soon
Reply 0
Mar 18, 2012 | 10:04 AM
Reply 0
Mar 18, 2012 | 10:47 AM
Quote:
That would drive me nuts..
Reply 0
Mar 18, 2012 | 11:15 AM
Quote: That would drive me nuts..
im okay with it bc its the only flaw. i got the car for 14k out the door all serviced at infiniti of orlando, 1 owner (50+ year old man) 48k miles. after i looked at so many sedans the was the best i could find for the money.
Reply 0
Mar 20, 2012 | 07:42 PM
I'm not sure if you can see the warps. It looks like between the warps is where the airbag is located. Does anyone have any idea why those 2 warps would be there where the airbag is? Thanks in advance. Ive searched around and nobody else has had this issue but maybe someone has insight about what might have caused this.
Reply 0
Mar 20, 2012 | 07:52 PM
That sucks. Any plans to fix these
Reply 0
Mar 20, 2012 | 08:20 PM
Seems to be somewhat common...I've heard from a few people who have had similar problems and I myself have a couple very small cracks. I dabbed some RTV on them just so they wouldn't spread. Not sure if that would work or look good on a larger crack though. Haven't heard of any other solutions for the problem. You could probably remove the dash and recover it in suede or vinyl or something like that....but removing the dash is a major PITA and I'm sure would cost a fortune.
Reply 0
Mar 20, 2012 | 08:29 PM
After driving S13s for as long as I have and seeing their cracked dashes (probably the most common cosmetic problem with those cars) these are quite minor.
Haven't ever seen a good fix for this issue, although I haven't spent a large sum of time looking for one either.
Reply 0
Mar 20, 2012 | 08:43 PM
Better to have that kind of crack in your dashboard than the kind that 'Messicans' smuggle into the country via hidden compartments in the dashboard.
Reply 0
Apr 30, 2012 | 01:58 PM
yes,my infiniti g35x is four years old and the dashbord is craking. i try to get the manufacurer to pay for the replacement. not lucky yet. maybe it is a time for a class action....
Reply 2
Apr 30, 2012 | 02:48 PM
A few questions for everyone with this problem:
Do y'all use any kind of UV protectant cleaner on the dash surface?
Do you smoke in the vehicle?
Have you ever treated the dash with Armor All?
Cracks in the dash result from the soft-touch material drying out and stretching. It's the same as when leather dries out. UV damage will cause this, as will Armor All. Armor All is silicon-based, and will dry the fabric out over time.
My G coupe is an '04. PO used 303 Aerospace Protectant on the dash, and I've been using Meguiar's protectant with Scotchgard in it. No issues here.
Reply 0
Apr 30, 2012 | 03:38 PM
I always cover my dash with windshield cover so the sun doesn't hit the dash. I know the sun causes the dash to crack over many years.
Reply 0
