Bent front crossmember.
Old Mar 18, 2012 | 12:55 PM
nightflyer's Avatar
So i didnt see cut off piece of steel at a parking spot & i got a bent front crossmember and maybe sway bar , the wheels are off and make a humming sound & power steering feels weird,I got most of it planned out (like taking it to the dealership,lol)exept one thing.What should be the worries of a bent frame and other issues. I WAS ONLY DOING 5 TO 8 MPH. thx in advance for the input.
Old Feb 20, 2014 | 02:34 AM
srisusa's Avatar
How did you get it fixed?
Old Mar 24, 2014 | 01:03 PM
hoarder23's Avatar
You may have bent a control arm, or a tie rod arm. Either way, you probably tweaked the tie rod end, causing the steering system to jam. Check your power steering fluid as well. The humming sounds like the rack or pump is giving you the required pressure.
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
derres
Aug 28, 2015 03:27 PM
miata007
Aug 17, 2015 04:36 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
