I have a 03 coups 5AT...i was debating on selling cause i want a 4 door but just cant yet...going to save up for a G8GT....so id like to do a couple of cheaper mods such as the plenum..
can someone link me to the one I need and the best price (i think ebay) and I dont know if I need copper or not...
I also found this install video on yourtube...is it really this easy?
Do I want to change the gasket?
thanks alot,
thanks alot,
herrschaft
close
- Join DateJul 2009
- LocationCoast
iTrader Positive Feedback100
iTrader Feedback Score(18)
Liked:771 Times in 605 Posts
You don't need the plenum, the MREV2 is basically your current plenum with some machine work. Its only the REV-UP engines that benefit from MD's plenum. All you need is a MD plenum spacer.
yea thats actually what I meant...worded it wrong....the video is just for the spacer.
herrschaft
close
- Join DateJul 2009
- LocationCoast
Not sure if your supposed to, but I kept the stock gasket on there when I installed mine. Haven't had any boost leaks yet. If it gets hot where you live then it wouldn't be a bad idea to get the ISO thermal kit as well.
Quote:
I left the stock gasket on there too. Maybe we did it wrong? Originally Posted by herrschaft
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
Most member here install the MotorDyne 5/16" spacer, if you go to the 1/2" like I have you can't use the engine cover. That's all you need for a first gen VQ motor with a AT....Gary
Ok good...I will just keep the stock gasket...didnt really want to go that deep into the engine..
can someone please post me a LINK to the one I should buy prefer ebay so I can use paypal.
thank you.
thank you.
seymore4
close
- Join DateMar 2009
- LocationWest coast
iTrader Feedback Score(114)
- My Ridem56
Liked:433 Times in 348 Posts
Why buy it from ebay? I'm sure one of the vendors on here will match that price or maybe even beat it
Quote:
+1...I know OC Infiniti sells them on eBay, but I'm sure if you PM them they'll probably give it to you for the same price.Originally Posted by seymore4
Quote:
http://www.ebay.com/itm/MOTORDYNE-BA...#ht_3708wt_932Originally Posted by That's G
id try to pick up a used one for a much better deal. check on my350z as well if none are readily available
seymore4
close
- Join DateMar 2009
- My Ridem56
There's one for sale in the classifieds for $150 right now, scoop that and save some money
seymore4
close
- Join DateMar 2009
- My Ridem56
Quote:
Gotta remember that they get owned for ebay fees when you purchase there... might as well help em out and buy straight upOriginally Posted by That's G
