Tank only fills half way???
Old Apr 13, 2012 | 06:47 PM
TruGame's Avatar
My tank only fills halfway, is there a upgraded fuel pump I can get or should I get the factory pump if that's the problem help help help
Old Apr 13, 2012 | 06:51 PM
Majiks's Avatar
it has already been discussed in countless threads, please do a search and it could possibly be on the FAQ master thread
Old Apr 13, 2012 | 07:06 PM
06G35Coupe94's Avatar
Had the same problem for like a month, but it went back to normal now...
Old Apr 13, 2012 | 07:38 PM
Exceptional's Avatar
I have the same problem on my '03.
Some pumps fill it up more than others. Also, holding the pump a certain way a bit sideways and not fully inserted puts in more gas too.
Mine goes up a bit over 3/4 full now so I don't really care anymore Im not wasting money on fixing that.
Old Apr 13, 2012 | 07:39 PM
petesg35's Avatar
There is a TB on this.........
Old Apr 14, 2012 | 04:20 AM
Hiro's Avatar
Had this problem since I've owned my G. Came to the forum, did a search, found the answer Since I don't live in the states, I have to work around it, but you might be able to go to the dealership and have this issue fixed. What I was doing for number of years was waiting till the tank was almost completely empty and filled it then. But, that doesn't always work. The best way that works for me is to only put the nozzle in halfway or so. Just don't put it in all the way. Then when the gas is being pumped, only apply half pressue. Don't pull the trigger full throttle like. This works for me and I can fill it all the way no matter how much I already have in the tank.
Old Apr 14, 2012 | 07:31 AM
wvu_ftw's Avatar
mine's been doing it randomly too. i just figured it loved me too much to make me keep spending $4.39 a gallon on it
Old Apr 14, 2012 | 02:19 PM
Also, FYI guys, I had 1/4 tank of gas when I got home, the next day it was like 1 millimeter from being empty. I thought I wasn't going to make it to the station.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
mbe32
Nov 13, 2015 11:09 PM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
