Best way to improve handling on a budget
Old Apr 17, 2012 | 03:34 PM
Swivel's Avatar
Moderator
+1 on sways, you could look at front and rear tie braces as well.
Old Apr 18, 2012 | 03:36 PM
jstudrawa's Avatar
Another +1 on sways. Went with Stillen, med settings take out about 1/2 the body roll. Going to try a few more settings when I get time..
Old Apr 18, 2012 | 04:21 PM
DrkBLuG35Sdn's Avatar
Hows the noise with swaybars? It seems like a fair number of people had squeaking from their hotchkis bars?
Old Apr 18, 2012 | 04:44 PM
Mr. Brett's Avatar
Lower tie bars are a good, cheap alternative for tightening up the bottom of your car if you don't feel like blowing $300 on a set of sways.
They'll keep the bottom half of the suspension from flexing outward when you go over dips and bumps in the road.
Honestly, though, the best way to tighten everything up is to go through and replace everything that's already on the car that might be worn, and then worry about sway bars/tie bars later.
You'd be amazed what a fresh set of bushings on the front and rear control arms can do for the car.
Old Apr 18, 2012 | 08:34 PM
herrschaft's Avatar
If the bushings are greased properly there shouldn't be any noise. I've had Hotchkis swaybars on for 2.5 years and they don't squeak.
Old Apr 18, 2012 | 09:19 PM
Footballmania32's Avatar
I'll second bushings. I replaced my torn front lower control arm bushings with Whitelines and wow, what a difference. Granted, anything would feel better than a torn bushing. But I'm certain the gains would still be felt on a worn bushing as well. Next is my compression rod, lower shock mount, and possibly subframe bushings. I plan on ordering some MD swayed when they are back in stock. they are currently back ordered.
Old Apr 18, 2012 | 09:28 PM
Upgraded Endlinks or just plug and play with the Hotchkis?
Old Apr 18, 2012 | 09:32 PM
herrschaft's Avatar
I'm still using OEM. I believe the 05+ had slightly stronger end links, can't remember for sure though. Nonetheless, none of my endlinks have broke yet. I did however break the driver side endlink bracket that mounts to the frame/unibody. So it was just plug and play for me.
Old Apr 19, 2012 | 09:21 AM
aaron3719's Avatar
anyone has any experience with KYB AGX on Tein H or S tech?
Old Apr 19, 2012 | 10:53 AM
gary c's Avatar
Originally Posted by Jairen
Sways gave my G an overall tighter feel throughout the turns. Really helped in the canyons. Suspension mods are moot without good tires and tire pressures. Michelin Pilot Sports coming soon for me. Another thing that is overlooked is the bushings and endlinks.
Not overlooked Jairen, I've been running Stillen sways with poly bushing, SPL endlinks set on medium along with Michelin PS2s on all four corners for 3+ years. All were complimented with Bilstein 10 way adjustable shocks and Tein 350Z H-Techs. SLICK will out corner my wife's Vette and roll like a dream....driveways/speed bumps and parking lots are our only nemesis.
Gary
Old Apr 19, 2012 | 11:49 AM
jstudrawa's Avatar
Gary
Gary, what setting are your sways on?
Old May 16, 2012 | 11:52 PM
NYT's Avatar
NYT
Have you read the suspension 101 thread on my350z?
Can you link?
Old May 17, 2012 | 01:51 AM
herrschaft's Avatar
Originally Posted by NYT
Can you link?
http://my350z.com/forum/brakes-and-s...ion-101-a.html
Old May 17, 2012 | 02:00 AM
JOKER's Avatar
CLUB MODERATOR
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Tmatheso
Dec 13, 2015 03:24 PM
NailBomb
Oct 28, 2015 07:53 AM
