Oil Leak Mystery
Old Apr 29, 2012 | 01:26 AM
trulegend's Avatar
Question Oil Leak Mystery
I have a 05 6mt with around 96k miles, i noticed the other day underneath the car there was minor oil spot. The bottom of the carriage is completely dry.
So few days ago when i did the oil change I removed the undercarriage to get to the filter and oil, is bone dry, no signs.
Then i drove the car everyday and looked for spots in the garage where i park overnight, no spots. I have not driven it since Thursday, today i took it out to wash it, and noticed there was a fresh oil spot underneath the car.
Again i checked underneath and do not see any signs, i also removed the engine cover and do not see any oil signs.
Any ideas?
When i did the oil change there was about 3.5 quarts of oil that came out. The dipstick shows the oil sign as high.
Old Apr 29, 2012 | 01:45 AM
trulegend's Avatar
ok, i did a little more research, could it be my o-ring on the oil filter?
How can i tell if that is leaking? Like i said i dont see a new spot everyday, like if the car sits for a while then i see it.
Also, since i just did an oil change with 5w30 synthetic stuff, should i just wait for another change, 4-5k miles, or just do it?
thx
Old Apr 29, 2012 | 04:00 AM
Blue Dream's Avatar
I drove ttrank's car solo
I think you mean the o-ring on the oil cooler. When I bought my car 3 years ago I had that issue, seems like the original owner had taken the car somewhere that overtightened the filter and wore out the ring. I had a very slow leak, a couple of drips at a time, but I could see oily residue around the cooler (it's what the oil filter screws into).
Old Apr 29, 2012 | 12:54 PM
trulegend's Avatar
right...
so my question is can i re-use the oil filter? and drop the oil back in the motor that will drain from the oil filter area?
Or get new filter and oil?
Old Apr 29, 2012 | 01:34 PM
AuAltima3.5's Avatar
Filters are cheap, get a new one. The seals
Aren't meant for multiple uses.
You can just top off after you're done
Old May 3, 2012 | 06:22 PM
trulegend's Avatar
ok so this morning, i opened the bottom up to replace the oil cooler o ring, and also took a closer look.
The oil cooler area was completely dry like, no sign of a oil leak, however i did replace the o ring since i already bought it and there was a Orange one in there, the new ones are black, i take it, it was never replaced.
looks like at some point the previous owner had replaced the oil pan or gasket, because of the gasket is non-factory, 3 bolts were a bit oily but the oil was black so it could be old oil. Rest of the bolts on the oil pan were bone dry.
Question, can i put some high gasket silicone on the 3 bolts if they leak is coming from there, i can only see oil stain if my car sits for more than 48 hours.. Very slow leak
see pics of the 3 bolts on the oil pan.
Old May 3, 2012 | 06:23 PM
trulegend's Avatar
pics
Old May 3, 2012 | 06:50 PM
trulegend's Avatar
Some update,
I was looking thru service records and at 87k during routing service, technician discovered oil pan was leaking and infiniti resealed lower engine oil pan. Parts used ultra grey gasket ma-999mp-am003p.
I am at 97k now and i believe the leak could be back, so in this case do i just use a silicone sealant and cover just the holes as mentioned above or redo the entire seal?
any help would be great.
thx
Old May 3, 2012 | 07:11 PM
redpearl99's Avatar
i would redo the pan's rtv. Doesn't sound like the last technician did a thorough job
Old May 3, 2012 | 07:20 PM
trulegend's Avatar
Pans RTV??
I called the same dealership that did the work, looks like their warranty on the work was only good for a year so missed it by 2 months. They said it would cost around $200 to do it again.
is this a PITA? or can i do it myself easily?
thx
Old May 3, 2012 | 07:45 PM
trulegend's Avatar
i was thinking about ordering this and applying in the areas where i see the oil possibly seeping.
http://www.carpartsdiscount.com/auto...tml?3593=78904
Old May 4, 2012 | 01:42 AM
trulegend's Avatar
Anyone anyone???
Old May 4, 2012 | 02:08 AM
herrschaft's Avatar
Originally Posted by trulegend
Some update,
I would just replace the seal/gasket if that is where the leak is coming from. I'm pretty sure they're talking about the little piece of rubber that sits in between the two pans.
Old May 4, 2012 | 02:22 PM
trulegend's Avatar
Old May 4, 2012 | 02:38 PM
herrschaft's Avatar
I attempted to do this a couple of months ago but the silicone had the lower pan stuck on there and I was unable to pry it off. I also had extra piping in the way which limited my options. Ended up taking the car to a shop and they had it done in 2 hours for $120. If your able to separate the two pans then it shouldn't be hard. If I remember correctly there's 2 oil lines that need to be disconnected and a bunch of bolts (10-12) that hold the pan on.
