04 5spd auto rev matching possible?
Old Jan 10, 2005 | 06:22 PM
smj4's Avatar
Is it possible to make the 04 match revs when down shifting like the 05's? Can you reprogram it or something? Is it more complex than that? What actually tells the engine to blip up before the shift?
I want my car to do that.
Old Jan 10, 2005 | 08:10 PM
daniel3ooo's Avatar
what is rev matching...heard of it but don't know what it is...care to enlighten me?
Old Jan 10, 2005 | 08:58 PM
ZeroGen's Avatar
Omega Enthusiast
This has been covered already numerous times. Try doing a search.
I don't believe you could truly "rev match" on an auto.
Old Jan 10, 2005 | 09:04 PM
roadracer516's Avatar
Even if you could, the tranny would not like it!
Old Jan 10, 2005 | 09:05 PM
Aznteazer's Avatar
one option is to pop it into neutral then rev.
Old Jan 10, 2005 | 11:18 PM
smj4's Avatar
The 05 matches the rpm as you down shift to provide a smoother shift when you are in the manual shift mode with the automatic tranny. Its simular to doing a heel toe shift. The 04 just simply shifts.
The question is: can you get the 04 to shift like the 05?
Seems like it would be a simple mod, but I may be wrong.
Old Jan 11, 2005 | 07:03 AM
Wingsprint's Avatar
The rev matching on the 05' auto tranny works very well.
As far as modification to the older non-rev matching transmissions, It would involve changes to the hardware and software in the transmission. If you ever see the inside of a modern electronically controled transmission you would see that major changes are unlikley.
Old Jan 11, 2005 | 12:50 PM
dba4life's Avatar
I have to say the rev matching was a pleasant surprise on the 05. I had an 04 loaner today and could really feel the difference between the 04 and 05 when downshifting in "manual".
Kevin
Old Jan 11, 2005 | 04:36 PM
KAHBOOM's Avatar
Kevin
same here.. I had an 05 loaner last week, the shifting is much more pleasant and it is much easier to doule even tripple shift without popping your wrist out of joint
Old Jan 11, 2005 | 04:52 PM
kenempireex's Avatar
I have an 05. I know it has rev- matching, but does it hurt the car if we downshift to slow down the car too much?
Old Jan 11, 2005 | 09:18 PM
speedeezx's Avatar
I've managed to do it on my 03, the timing is key.
You need to downshift then immediately blip the gas almost to the point where your doing both simultaniously. With the .25/.05? second delay the transmission has between shifts you can rev up the motor freely and then catch the next lower gear as your rpm's are coming down. It's pretty hard to do effectively all the time but you'll know when you hit it right.
Now trying to modulate the brake with the left foot smoothly while doing all the shifting and blipping is my problem.
Was that any help?
Old Jan 11, 2005 | 09:34 PM
EricIsKlumzyee's Avatar
Was that any help?
try to step on the brake and blip the gas with the same foot..
i dont think the tranny would like you for helping it rev match just let it work itself? you shouldnt be changing the gears too much on an auto anyways but when you down shift you can put some pressure on the gas and it'll be smoother and let off the gas when your upshifting.. iono if thats any good for your tranny though.. i've always been told to stay off the gas
Old Jan 11, 2005 | 11:44 PM
s4m222's Avatar
uses the brakes to brake... not the transmission.... but using the transmission to keep the speed down, say... going down a LONG hill instead of letting the auto shift to 4-5 so u start speeding up, if u MM to 2nd or 3rd it should keep ur car from speeding up too much....
Old Jan 12, 2005 | 01:14 PM
smj4's Avatar
Back to the original question
I take it no one has a definitive answer on whether or not you can get the 04 to blip the throttle automatically as the 05's do.
I had an 05 loaner for a few weeks as my 04 was getting re-painted. the down shifting while it was clicked over to manual mode was amazingly smooth. The nice thing was that if you were slowing down for traffic or something and say you were in 4th, but should have been in 2nd while at idle it bliped the throttle and avoided the jerk of shifting while going to slow. It also made it easier to avoid "engine braking" by downshifting because you could hit the brakes and then find the correct gear.
Heal toe shifting (which is only possible with MT, and is the desired result of the auto rev matching) and engine breaking have been covered in other threads.
Old Jan 12, 2005 | 08:02 PM
Msedanman's Avatar
O.F. Administrator
Not a feature of the G, but it is with other Infinitis such as the new M45.
Talk to the dealer about this he may know of a reprogram available for your G.
